Question about X2Gen MG15VT 15" LCD Monitor
I need a cord to hook up the monitor to the computer
  • 755 Answers
Go to BestBuy or Walmart and get a VGA video cable. They can be had for about 10 bucks. Look at the plugs on your monitor and video port on your computer to make sure you get the proper ends on your cable. It will be either male-female or male-male ends.
I hope this helps.
Posted on Dec 11, 2009
Monitor says no signal
if no signal the cause is either the source not connected like the pc the vga cord not hooked up or a monitor failure. to isolate weather it was monitor problem, if you have other monitor you can hooked up just to ensure if the cause is with in the monitor. by the way you must also considered the vga cord which need replacement.
Nov 10, 2012 | Computers & Internet
Hook up to the CPU
Two cables are needed, Power and Data signal (VGA). Most monitors take the same type of power cord as computer power supplies. (Some computers will allow you to plug in a slightly modified cable that will power the monitor off the computer's power supply. This cord has similar ends on both sides (with the prongs inside a rubber housing). The only issue with this is it makes the power supply work harder and thus can fail sooner.) Most computer supply shops (online and brick-and-mortar) will have the power cables, if you don't have extra cables hanging around.
I hope this helps.
Mar 20, 2010 | Gateway 7004618 (Black) 17 in. Flat Panel...
I tried to hook up my dvd player and i get picture but no sound. when i put the cords in the back of the monitor there is yellow red blue green holes no white spot. Do i need different cords. I have tried...
That could be a result to that TV either not having the ports you need, or you may need different cords. On my TV. With the 360 they have two cords. Red,white, and yellow and also green blue and i think red but im not 100% sure. You may need to find a different port on your TV for your cords, or do what I do and have your VCR hooked up to your tv, and your DvD player hooked up thorugh your VCR. Hope this helps and don't forget to rate ^^
(and yes that yellow and white are a necessity)
Feb 23, 2010 | Computers & Internet
Moved computer to new location. rehooked all. monitor wont start
Without seeing your make or model on you monitor it is difficult to give you any advice.
But with that said.. If your monitor is a flat screen there is a power cord that plugs into the wall the cord is connected to a small box (power converter) out of the box is a small connector that goes into your monitor. It is small and you may have to turn you Monitor over to see exactly where it connects.
Your computer will work whether or not you have Internet service.
Sep 08, 2009 | Star Logic 17" LCD Monitor
My monitor is connected, as is my graphics card, but when I turn my computer and my monitor on, it says that there is no input signal.
Hello there:
I would start by trying a different monitor to eliminate the possibility of a faulty monitor.
if nothing happens you are going to need to investigate the video card. you can turn off the computer and open up the case and remove the power supply to the motherboard cord.
now remove the video card from the board and check to see that it isn't damaged or dirty . you can try to put it into a different slot if you are able to. now just hook up the powersupply cord back up to the motherboard and hook up the monitor to the computer and power up the computer than the monitor and see if it works if still nothing than i am sorry but you will be needing a new video card ok? i really hope that this is very helpful
best regards mike
Jul 31, 2009 | Computers & Internet
Monitor
Monitors need power cords to function, & there is nowhere near enough power in the data cable to power the monitor. So, it sounds like the power cable got pulled out somehow and is now lying on the floor. The power cable will be a small plug like you have on a radio or other similar devices instead of the standard sized plug that older monitors have. Once you plug the power cord back in, it should be fine.
Jul 01, 2008 | Microtek C783GM 17" Flat Panel LCD Monitor
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
X2Gen MG15VT 15" LCD Monitor Logo
Top X2Gen Computers & Internet Experts
jason
Alun Cox
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
