Question about SmartDisk FireLite 80 GB Hard Drive
Not showing any signs of power, and computer not seeing new hardw
Have Smartdisk by Verbatim 80gb (firelite) It is actually my accountants. And plugging it in via the USB I can not get any acknowledgement from the computer saying it sees any knew hardware. Seems like the SD is not powering on or something.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 72 Answers
Try using a different power cord because if there is no power nothing will happen on the computer
Posted on Dec 26, 2009
On my smartdisk firelite the conection that excepts the usb cable has broken. I need data thats on the hard drive how would I get this info off the firelite?
you can open the case and remove the hard drive and install it in a new external usb case for it.
you can find out what type of case you need after you open it. it could be either a SATA connection or IDE.
If it is a SATA and you got a SATA cable/power you could also just install it directly into your computer and grab the files you need.
Mar 11, 2011 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Hi, I have two Verbatim Smartdisk external drives (Firelite Model No. 47551) that we were using as a backup medium. They have been replaced by larger RDX drives but I would like to use the Verbatim...
If you did not receive a driver disk with your Smartdisks when you purchased them than you do not need to install any drivers. However, depending on which windows operating system you are using, your smartdisks may not be compatible. What you should do is go online to the Verbatim website and see if your model is compatible with the operating system you are using.
Feb 23, 2011 | Verbatim SmartDisk Firelite Portable USB...
MY COMPUTER DIED. HOW DO I TRANSFER THE FILES FROM MY VERBATIM SMARTDISC FIRELITE 160 GB, USBFLB160' TO ANOTHER COMPUTER? THANKS...........................JOHN NICKERSON
It depends on how you copied your files to the SmartDisk.
If you used the "normal" method of copying files/folders in Windows, then just connect it to the new computer.
If you used some "backup" software from Verbatim to write "backup" files,
then you'll need to install that software on the new computer,
in order to retrieve from those "backup" images.
Nov 13, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
My USB smartdisk firelite is not recogniced by any laptop, regards
Connect it to a different DESKTOP computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 29, 2010 | SmartDisk 80GB FireLite USB Bus-Powered 80...
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
My verbatim portable hard drive usb 2.0 250 gb does not work anymore. I need to install usb driver ı think what u recommend
Friend:
You need to describe this prpblem with more detail....
No signed of power, have power but no access to data, spindle spins, ettc?
Thanks
D
Dec 16, 2009 | Verbatim SmartDisk Firelite Portable USB...
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Verbatim firelite external hard drive
ok...well...then if it is compatible with your current operating system, then it should work. is this a first time install?
Oct 13, 2008 | Verbatim SmartDisk Firelite Portable USB...
How to back up photos on MacBook
From within iPhoto, try saving/exporting directly to the drive.
Jul 09, 2008 | Verbatim SmartDisk Firelite Portable USB...
SmartDisk FireLite 80 GB Hard Drive Logo
285 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Alun Cox
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
