Furnace comes on for 5 min then turns off diagnostic light flashes 4x's it a goodman furnace gmp075-3
How can i do my aircon remote control not work?
Posted on Dec 11, 2009
Goodman furnace Model GDS80703AXBB -fan comes on then igniter light comes on, then burners turn on but shut off right away and wont stay lit. Now igniter light wont come on so burners not coming on at...
Sounds like either the flame sensor is not working.
The sequence for starting the furnace is:
1. extraction fan on
2. pressure sensor (for fan)
3. ignitor (spark or glow plug) comes on
4. gas valve opens up
5. ignition of flame
6. flame sensor (or temperature sensor)
7. plenum temp. sensor
8. main fan starts
It is most likely that the flame sensor is dirty or gone,
or (and I hope not), the module is gone and needs to
be replaced.
Sep 10, 2017 | Heating & Cooling
Furnace will not light,on Goodman Furnace model#GME80704BX
Is the gas turned on or does it come on but goes off quickly?
Oct 06, 2012 | Cozy Enclosed Front Console Heater 70,000...
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
Furnace lights and in about 2 to 5 mins. the flame shuts down. the furnace trys to relight but does not. the unit trips out and the light flashes 1 time to show to many times tryin to light
Probably a filthy flame sensor. You can clean it off with steel wool or light sand paper. This should do it for you. If this does not work I would suspect a gas valve that is failing and dropping out after a few minutes. Always remember to change the filter while you are at it. Good Luck :)
Dec 03, 2010 | Goodman GMS90703BXA Heater
Heater won't heat very long
there isnt a pilot if it has jets , it has a Hot surface ignitor. you should see a glow and then the jets light , if its running for a few min it may be overheating, have you changed the filter recently? you should also have a flash code you can locate when the furnace shut off and is no longer doin what its supposed to look thru the bottom door peep hole and watch for a series of red flashes. if you remove the cover after retrieving the flash code there will be a chart on the inside of the cover that will tell you why the furnace is shutting off. by the way the model # you gave is for the A/C coil above the furnace, not the furnace.
Oct 10, 2009 | Heating & Cooling
Yesterday the furnace was working and now doesn't come on.
You will need to have a service technician come out. It could be a fuse out on the board, a bad board or several other problems in the circuit that can only be determined by a professional on site.
Oct 03, 2009 | Goodman GMS807034ANA Heater
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Furnace integrated control module
The light is supposed to be on, if there is a fault in the furnace the light will begin to give u a flash pattern... ie; three flashes...or two flashes.. on the furnace exterior or on one of the doors there should be a fault code chart.... read the chart on the unit it will tell you what light is on and when..
Jan 14, 2009 | Goodman GMS90703BXA Heater
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
