Question about Zoom Wireless-G 4410 (44100000) 802.11g/b
Opening the file
Every time i open the file it closes 1 second later
  • robhagg May 23, 2008
    Same thing install the files, turn off pc - attach Model 4410 Wireless-G USB Adapter turn on. run program and doesn't start. un-installed and reinstalled, checked device manager mmc - all good, but still wont start program and hence wont work - down loaded the newest drivers but have not had a chance to try them yet - as it is for a friend! any suggestions please:)
  • Jimmymc May 23, 2008
    Exactly same problem. Try and open it up and it shuts within a second. All subsequent attempted openings are just ignored. The software was working fine until a couple of days ago when it became eratic. Decided to try uninstalling then reinstalling and not had it work since.
  • 196 Answers
What file?
What computer?
What OS?
Posted on Jan 21, 2008
6ya staff
SOURCE:
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Adoobe Illustrator problems
Correct the offending command
1.Launch Illustrator.
2.Using File > Open, hold down Command + Ctrl + Alt + Shift (Windows), and click Open. Double click the file to open. You want the full Open dialog.
3.Your file will be blank. Close the file without saving or altering.
4.Go back to your directory. You will now have a second file with an underscore at the beginning of the filename. (myfile.aivs._myfile.ai).
Nov 03, 2014 | Adobe Illustrator CS2 for PC
DVD Tray will not stay closed
There is a leaf switch inside the loading mechanism, which detects the tray to fully closed state. If this switch has damaged, this kind of fault will occur. To repair it, you have to open the set, and take the loading mechanism out, and disassemble it. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 06, 2013 | Haier TDC1314S TV
Craftsman 3/4 hp Chain opener.....Door opens and closes by itself. No blinking light, looks like everything is clear with sensors. Half opens then closes, then door completely closes and 5 seconds later...
You most likely have a bad wall control or the wiring to it. An easy way to check this is to remove the connection at terminal #1 on the rear of the motor unit. Just remember that your wall control will not work with this wire off. Your remotes will still work though.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unable to open a Publisher file a second time without rebooting PC
have you upgraded from xp to vista since you installed the microsoft publisher?
it sounds like your publisher is not closing the prior instance running. you can bring up the task manager and watch what is happening when you open and close instances in publisher. in task manager click on processes and watch what comes and goes as you work with publisher.
then if it continues, i would reinstall you publisher all together. the consensus among the gurus is it will running but it 11 yrs old and may have issues that can;t be patched for vista.
May 23, 2009 | Microsoft Publisher 97 Full Version for PC
Craftsman 1/2 HP door opener bounces back open
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
Disc Tray wont stay shut
A lot of people have this problem. Before you post, look around.
Anyway, I was able to call xbox 360 customer support. We did the troubleshooting but it still would not work, so they took my xbox 360 in for repairs. I would not try to fix it on your own because it might negate the warranty.
Xbox Support: 1-800-4MY-XBOX
Jun 22, 2008 | Microsoft Xbox 360 Console
Microsoft works 7.0
From the Microsoft Office 2003 Web site:
Excel 2000 or later versions cannot directly open files created in Microsoft Works version 3.0 or later. To open a Works file in Excel, first open it in Works and use the Save As command to convert it to one of the file formats listed below. Then close the Works file and open the converted version in Excel.
  • Works for Windows 2.0/Works for DOS SS
  • Excel SS
  • Lotus 1-2-3
To open a Microsoft Works database file in Excel, first save the file in Microsoft Works as a dBASE file, and then open the dBASE file in Excel.
Feb 11, 2008 | Computers & Internet
Zoom Wireless-G 4410 (44100000) 802.11g/b Logo
Top Zoom Computers & Internet Experts
Paul Castley
Paul Castley
Prashant M
Prashant M
Ekse
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
