Question about Brother DCP-585cw All-in-One Wireless Color Inkjet Printer
Scan Issue DCP-585CW - "Check Connection"
Scan Issue - when I press the scan button on the DCP-585CW, the message "Check Connection" shows on the display - what should I do in order to be able to print? Chris
  • christian660 Dec 11, 2009
    ...- what should I do in order to be able to SCAN? Chris
5 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: brother DCP-110C printer/copy/scan/photocapture
so please tell us, what does the display tell you? Is it unable to clean? If so search for "unable to clean" or Error 46. This is explained a thousand of times here...
Posted on Mar 16, 2008
technotech
  • 183 Answers
SOURCE: scan will not work
Step one: Make sure that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon (c01387841.gif ) normally appears in the Notification area at the lower-right corner of the computer screen. The monitor is ready when a check mark appears on the icon after you start the computer. If the Digital Imaging Monitor is in the system tray, skip to 'Step two: Populate the Destination List.' If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software. Click here to go to Step three: Uninstall and reinstall the software .
  5. Select the HP Digital Imaging Monitor check box.
  6. Click Apply , and then click Close .
  7. Click Restart to restart the computer.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to fill out the destination list.
  1. Open HP Solution Center with one of the following methods.
    • On the Windows desktop, double-click the HP Solution Center icon (c01425508.gif ).
    • On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after you turn on the printer or computer.
  6. Click each program to include on the Scan To list.
  7. Click the Add arrow.
  8. Click OK .
  9. Scan a document using the Scan To button on the front panel.
    • If the scan fails, try to scan using the HP Solution Center Scan button.
    • If the scan still fails, continue to 'Step three: Uninstall and reinstall the software.'
Step three: Uninstall and reinstall the software Uninstall the software
  1. Unplug the USB cable connecting the product to the computer. CAUTION: Do not reconnect the USB cable until the on-screen instructions prompt you when you reinstall.
  2. Click Start , click Control Panel , and then double-click Add or Remove Programs .
  3. In the list of installed programs, click the HP product, and then click Remove .
  4. Follow the on-screen instructions to complete the software removal. NOTE: If asked to remove shared files, click No . Other programs that use these files might not work if you delete the files.
Reinstall the software
  1. Turn the product on.
  2. Open a new window to browse to the Select Software and Drivers page:
    1. Right-click this link, Select Software and Drivers , and then click Open in New Window .
    2. If prompted, type your product number. You might also need to click it in a list of similar products.
    3. Click your operating system. (If you do not know, click Start, right-click My Computer on the menu, and then click Properties .) The Select Software and Drivers page opens.
  3. Click the Full Feature Software and Drivers option.
  4. Click Download only . This option allows you to install the software at any time after the download completes.
  5. Click Save , and then browse to the location on your computer where you want to save the file.
  6. Click Save . The software downloads to your computer.
  7. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe
  8. You can accept the default location to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  9. When the Install Wizard starts, follow the on-screen instructions to install the software. Important : If you choose a Custom type of installation (available for some products), make sure to install HP Imaging Device Functions so that you can scan from the printer. The Recommended installation type installs this feature automatically.
  10. After successful installation, scan a document
Posted on May 08, 2009
Jimsta01
  • 405 Answers
SOURCE: I am trying to scan with a brother-MFC_490cw and
Its asking to check connection between the brother and the computer.
Posted on Mar 27, 2010
SOURCE: MFC-665CW Scanner keeps saying Connection Failed
I think I solve the issue for scanning so far. Here's what you do goto control panel -> Scanners and Cameras. Then right click into propertise, then check Specify your machine by address. It should already have the printer IP address listed in the box below. If not our can goto to your router and see the ip in the DHCP Client List .
After this I'm able to use the Control Center 3 scanning.
I think the problem was the NODE name list in the setting in my winxp pro does not match the actual NODE name the printer is using.
Posted on Jan 20, 2011
I have brother DCP 7055 it shows print unable 71 error pls suggest
This is due to Polygon Motor Error in the Laser Unit.
Pls try one of these:
1. Input the correction value of the laser unit correctly.
2. Check the harness connection of the laser unit. Try re-connect them.
3. Replace main PCB Assembly.
4. Replace the laser unit.
Mar 02, 2015 | Brother Dcp-7055 Laser Print Copy Scan...
Why won't Brother DCP 7020 Scanner connect to computer?
Try opening the Scan function from the computer and pull it from the MFP printer instead of being at the scanner trying to push it to the computer. Your Brother DCP 7020 would have to be on the same network and installed on the computer you are trying to use. Check your usb cable, Ethernet cable or if wireless - check the Wi-Fi connection settings (network name and correct passphrase).
Aug 30, 2014 | Brother Dcp-7020 All-in-one Laser...
Brother DCP 585CW unable to print error 46
A possible reset might solve hence remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Mar 21, 2011 | Brother DCP-585cw All-in-One Wireless...
How do i load A4 photo paper in my DCP-585Cw Printer
Visit this link to download user guide for DSC-585CW and see page-13, it is about how to load the photo paper.
I hope this will solve your problem,
Good luck and have a nice day
Rating the solution is highly appreciated.
Aug 18, 2010 | Brother DCP-585cw All-in-One Wireless...
My brother DCP-585cw printer prints too slow. What can I do to speed it up?
Go to the control panel and then into the printers section. Right click the DCp-585cw and select printing preferences. Under the section quality chose fast. This should speed things up.
Mar 31, 2010 | Brother DCP-585cw All-in-One Wireless...
When I press Scan on my Brother MFC440CN, I get an error message ''Check Connection''. I just want to scan a picture to card, which I did many times without an issue.
instead of scanning using the button on the machine try it from the computer. Brother normally gives the control center program, you can find it in all programs in the brother folder. you should be able to scan from here. if not there is probably a connection problem from the printer to the computer
Mar 24, 2010 | Office Equipment & Supplies
Printer printing in with stripes
You can try to perform a power purge, do it by the following:
  • Enter maintenance mode. Either with starting your machine with Menu button down, or by pressing Menu, 2, 8, 6, 4 quickly. The fax/copy/scan buttons should flash/be lit.
  • Press 7, 6.
  • Press 3, the machine should now say something like "POWER_P" or "P_PURGE"
  • Press Mono/Black start, the machine should now say "cleaning".
  • When it's done, the display should say Maintenance, and you can leave this service mode by typing 9, 9.
You can now try printing a test page again, the result should hopefully be better.
Be noted however, that this purge takes ink from your cartridges, but it's more likely to solve the issue then just trying to do more "regular cleaning".
Jun 14, 2009 | Brother DCP-585cw All-in-One Wireless...
Nov 15, 2008 | Office Equipment & Supplies
What are the instructions to scan using Brother DCP 1000? I laid the docment face down and pressed Scan To and nothing happens but showing another selection in the glass window.
To Scan on Brother DCP 1000 you need to click on the "Paperport" Icon on the desktop. Then Click on "Twain." Lay your document to be scanned face down on the scanner glass. Press the "Scan To" button on the Brother DCP 1000 printer. On the "Twain" window click on "Start." Note: When I clicked on "Start" it initially scanned blanks. I clicked on "PreScan" and saw an image. Then I again clicked on "Scan" and it worked. I named each document I scanned and saved them in a folder for later use.
Jul 31, 2008 | Brother DCP 1000 All-In-One Laser Printer
Brother DCP-585cw All-in-One Wireless Color Inkjet Printer Logo
466 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
