Question about Maytag Neptune MCE8000AY Electric Dryer
Dryer squeals when running - Maytag Neptune MCE8000AY Electric Dryer
  • 715 Answers
Replace belt
Posted on Dec 11, 2009
Squeals while drying clothescould this be a bad belt ?
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
Mar 29, 2014 | Kenmore Elite HE4 Electric Dryer
Squealing dryer
Sounds like the drum bearings are going bad, or at the very least need lubrication. thats what your problem is.
Jan 25, 2008 | Estate TGDS740JQ Gas Dryer
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Kenmore series 80 Gas Dryer, in back of the dryer there is a fan at the bottom that squeals when I turn the dryer on. Is this easy to replace or oil to resolve the squealing. Suggestions are...
that fan runs off the motor shaft and can be lubed with some spray lube,, be sure that its not the belt thats squealing, check it for cracks, and bare spots
Jul 06, 2011 | Dryers
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
Kenmore solid state dryer. was squealing while running. now drum stops and starts. still squeals
belt, idler pulley, drum glide/rollers:
belt/idler pulley:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
rollers/glides:
http://www.partselect.com/dryer+replace-glides+repair.htm
belt configuration
http://www.applianceaid.com/images/belt-config.JPG
Dec 03, 2010 | Kenmore Dryers
When running it has a very high squeal after it has been turned on a few minutes. maybe a belt issue?
es the belt runs on a belt tensioner that has a roller with a breaing inside the roller. The bearing is locked up causing the roller not to move no longer. This is making the belt squeal. If ran much longer the belt will burn off deleting the squeal although the drum will not turn. Replace the belt and the roller assembly. The tensioner will still be fine to use for it is a spring tension device that out last any dryer
Mar 26, 2010 | Dryers
Amana Electric Dryer Model NDE 7800YW squeals when running will quite after 5 to 10 minutes
my amanadryer will run for 10 minutes and then start squealing and quit.wait 15 minutes and it will restart and do the same thing. any help???
Mar 09, 2010 | Dryers
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
89 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
