Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Have stihl ms 210 chainsaw cranks will idle boggs out when you give it gas adjust highspeed then want idle been threw carb twice its clean [ help]
    Problem Solver:
  • 12 Answers
If it is ideling ok I would check the air filter first , try running it without filter in clean air enviroment, Then check the spark plug, clean or replace if necessary, then attempt adjusting carb...
Posted on Dec 12, 2009
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How do I change a chain on a Stihl ms 210?
Take off the side cover at the base and loosen the tension screw. Blade should slip off. Make sure when you replace it, you do not tighten it too far.
Sep 20, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Stihl chainsaw problems
Your dealer is right. Gas is not a carbs best friend. every time you fuel dirt gets in the fuel tank from the air. This eventually blocks air and fuel passages and check valves inside the carb. That is the reason. Carbs wear out like anything else. Check the price of a carb compared to a kit. Some Stihl carbs are reasonable.
Jul 21, 2014 | Stihl Garden
Chainsaw blade rotating when idling
Could be dirt in the carb or a dirty air filter. A good clean is in order I think!
Feb 04, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
My stihl ms 260 chainsaw wont idle down to low idle
High idle is usually a sign of running too lean, or having an air leak around the carburetor mount, or even somewhere else on the machine. if turning the low mixture screw out half a turn or so doesn\'t help, I\'d start looking other places for a leak.
Check things like the plastic plate the carbie mounts to (intake manifold) and all the gaskets associated with that area.
Also, check your fuel lines aren\'t perished, they can cause air to suck up into the carbie and cause issues.
If you still have no luck it\'s possible one of the main crank seals may have gone, causing air to suck in around the crankshaft.
This is best left to a qualified small engine repairer to replace, as they can be dicky to get in there without damage.
Hope that helps!
Nov 17, 2013 | Stihl Garden
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
The chainsaw boggs down immediately when it contacts the wood. It runs somewhat choppy as well at idle. It is new to me and this is the first time I ran the saw. Is this a carb adjustment thing? plugged...
Clean the air filter. Remove, clean, and reinstall the muffler and spark arrestor.
If my new saw I would consider a Stihl mechanic tune up $40±. New plug, new fuel filter, pressure/vacuum tests and carburetor adjustment.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna Chain Saw 20" Bar
Stihl MS 260 Pro wont run wide open or idle.
Hi brandon First change the sparkplug with the same heat range,Check and clean the gas filter with compressed air.Remove the carb and very carefully disassembly entirely.Check the gaskets and the diafragms.At the fuel pump side there is a fine screen(clean it).Check the needle,the spring and lever.Unlock the screws L and H(note how many turns are they).Put the corp of the carb in a special clean solution for 12 hours and then clean it with compressed air(something is clogged there).Put all back together and try to start the engine. regards savumihai71
Feb 12, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Bent connecting rod
Ive had blower with bent cranks due to blower scroll comming off and the engine over reved
Jan 18, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
1,633 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
