Question about Minuteman C46000-00 Self Contained Carpet Extractor Vacuum
Jets quit spraying - Minuteman C46000-00 Self Contained Carpet Extractor Vacuum
My Minuteman c46000-00 isn't pumping any fluid through the jets. Would this be an alkaline problem, and if so, will baking soda and vinegar clear it up?
Also, where can I get a fix-it manual for this unit.
Does anyone know how old this unit might be??
Tks for your help!
Rick
Posted on Apr 20, 2010
Not spraying water
I have sk460 spray mop and the 6 volt spray motor rusted up.
Looking for motor now.
Dec 09, 2015 | Vacuums
How do I get the jets to work, I think they are clogged in the line
Your extractor is equipped with two quick change jets. They require a quarter turn (push in and turn counterclockwise) to remove. Remember to never use any metal tools to clean the jets (pin, scraper, razor etc.). If you are not able to pump solution with the jets removed, there may be a problem with your pump or solenoid. If you can hear the pump building pressure, but solution is not escaping your jet bodies, your solenoid may not be opening to allow the solution to flow. You should be able to hear the solenoid opening and closing (click). You may need to disable the vacuum motor to hear this happen. Be sure not to leave any solution in your tanks when storing. Especially high PH (alkaline) detergents. They will corrode and cause problems. I have included service manual for your machine in case you need part #'s or reference to where your parts are located.
PERIODIC MAINTENANCE
Twice a month, flush a white vinegar solution (One
quart vinegar to two gallons of water) or anti-browning
solution (mixed as directed) through the extractor. This
will prevent build-up of alkaline residue in the system. If
spray jets become clogged, remove the spray tips,
wash them thoroughly, and blow dry.
NOTE: Do not use pins, wire, etc. to clean nozzles as
this could destroy spray pattern.
Windsor Vacuums from HomePro Vacuum Centers Mini Promax Jet Windsor Commodore 20 86013200 8 601 320 0 Solenoid Valve Windsor Commodore 20 86258870 8 625 887 0 84168 http://windsorind.com/Upload/CPDCategoryDocuments/parts-list-commodore-20-115v-extractor.pdf
Jul 31, 2014 | Winsor Windsor Brushroll Assy Commodore 20
Bissell wont spray
You need to check the little spraying jets, many can be un blocked with a fine needle
Oct 24, 2013 | Vacuums
My eureka atlantis 2590 deep steam extractor will not spray
is the spray pump making a noise? if so, clean spray jets with a lime/calcium remover like "clr."
If the pump isn't making noise, try the rest fuse button.
If that's not it, your pump motor or solenoid is toast.
Sep 28, 2010 | Eureka Atlantis 2590A Wet/Dry Vacuum
Water wont spray out of bottom carpet cleaner but will out of the scrubbing hose
First try putting in a little hot water in the water resevoir , let sit for about about 5 mins. then try it. if this doesn't work, flip the machine over and locate the spray jets on the bottom. You'll need a pin or something small enough to clean out the jets bye sticking pin or paperclip in it . Detegent left in the machine sometimes cloggs the jets.Empty water before you flip the machine over.
Dec 12, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The unit sprays for the first few seconds after I turn the unit on and then stops spraying any water or solution. I turn it off, wait a few minutes and the same thing happens. What is going on and how...
This sounds as though the pump belt is slipping. This may be caused because the pump belt has stretched slightly or the pump is seized and will not turn. Remove the pump belt and turn the pump rotor with your fingers to see it turns freely. If it does then the pump should be OK but the belt may be stretched and will need replacing. If the unit does not spray after changing the belt then clean the spray nozzles at the front of the machine and make sure that water flows to the nozzles OK. You can check this by temporarily disconnecting the nozzles from the plastic pipes.
Main causes for no spray.
Bladder may be empty.
SmartMix Bottle may be empty.
The Filter may be clogged.
Tanks may not be seated properly.
Pump may have lost prime. Check all the fluid tubes / hoses for leaks or blockage (see below).
The Pump Belt may be broken.
2 front jets are blocked. This is a common problem. When the machine is standing for a while the detergent turns to a gel causing the blockage Lay the Bissell on its side then where the water comes out of the jets at the bottom of the machine unblock them using a pin to poke through the hole in the centre.
Try running hot water through the system with no detergent to empty out all the residual detergent. Keep running hot water through the system by pressing the button you press for it to spray the water do this for about 5 mins and keep swapping the water for hotter water as it starts to cool doing this 4 or 5 times might solve your problem if not get the tools out and start looking for the blockage. Do this once a month to ensure that the pipes and jets are kept clean and free of any detergent gel build up.
Oct 30, 2009 | Bissell 7901-R Clearview Proheat Plus...
Minuteman C46000-00 Self Contained Carpet Extractor Vacuum Logo
289 people viewed this question
Top Minuteman Vacuums Experts
Marvin
Marvin
JoeVacs
Are you a Minuteman Vacuum Expert? Answer questions, earn points and help others
