Question about Craftsman 20 hp 42 in. Deck Yard Tractor
I HAVE A CRAFTSMAN ZT7000 MOWER WITH A 20HP KOHLER SV600S ENGINE.I WENT TO START IT AND IT WAS HARD TO START. I CHANGE THE FUEL FILTER. IPUT A NEW PLUG IN. I CHANGE THE FUEL . NOW IT WILL START BUT IT WON'T TAKE GAS. IT RUNS HOT AND SEEMS TO BACKFIRE FROM THE MUFFLER. COULD IT BE THE TIMEING OR VALVES?
  • 123 Answers
Sounds like the float in the carb is leaking by the set.
Posted on Dec 12, 2009
Why is there gas under the air filter on a Craftsman Mower Kohler KT735 or is this normal?
needle and seat not closing of properly and allowing fuel to leak out
check for excessive sump oil level
Jul 01, 2017 | Craftsman Garden
Can the overhead valves on a 16hp sears craftsman with a kohler engine be the reason why it won't start and if so, can I adjust them
Valve clearances will also effect the decompression valve in the engine, if they are too wide the valve lifter will not work and the battary will not have enough energy to crack the engine.
Jun 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Kohler 20hp Craftsman mower started leaking fuel out of air filter and exhaust
i have been finding that the needle valve in the carb has not been seating from the newer fuel replace both the needle valve and the seat change the oil and you should be good to go i add a shut off valve to the ones i service and advise that the fuel be shut off when not in use and run the carb out of gas when not using for ever day
Jun 18, 2012 | Garden
How many hours of use can I expect to get from this mower?
the more you do maint on it the longer you will get oil changes filters shape blades help engine load do you ever take off the top cover and clean the cooling fins?do you climb hills?use it to pull loads arouund the yard?but the 20hp kohler engine has had problems cracking the block on top of the engine my mower has a 22hp kohler with 2236hrs on it starting to get tired
Jun 07, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need hydro drive wheel right side for craftsman zt7000
its a zt7000 craftsman homeowners sit down 0 turn mower.mower is made by simplicity 18 hrs koler. since i last posted i had a freind who works on hydro motors for a living break it down clean it and look for visual damage. there was none so it was put back to gether. new gasketts and lubed. after assembly neither side work at all now and makes a grinding noise when levers are put in reverse. left side worked before right side was taken out, left side was never touched. resovours were filled and everything was put back together correctly im positive. im at a loss with this.
Nov 01, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Tractor won't start. Acts fuel starved. I see very little fuel in the filter which is new. I suspect the fuel pump assembly is bad. Any easy way to test the pump? 20hp Kohler engine.
you can to this in two ways. pull the out put hose off, turn the engine. be vary careful, to see if fuel comes out. or do a pressure test about 3 to 5 pds. check the tank. I have seen flays and other ?? in the tank plugging the lines. blow air throw the lines (not the pump)
Oct 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
1,054 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
