Question about Yamaha AX-396 Amplifier
Hi,where can i buy remote controle for yamaha ax 396 ampl. and how mush..
  • Anonymous Mar 30, 2014
    There are pinholes in the back for plug I think what lead do I need for this and another lead to go from cd player to amp.
    Problem Solver:
  • 5 Answers
SOURCE:
Multizone set up
how many inputs does it have?
Mar 17, 2014 | Yamaha Audio Players & Recorders
Connect yamaha ax 396 to pc
Think aux sockets are line IN, on PC line IN too. Try finding line OUT on amp.
Nov 21, 2013 | Yamaha AX-396 Amplifier
What are the frequencies that the bass and treble controls on a Yamaha AX-396 amplifier control? I recorded alot of music direct from the amp to my pc with the bass and treble controls at max and need to...
The bass and treble controls (as well as volume) have no effect on the recorded output if you're using the traditional jacks a tape deck would use. Only PRE-OUTS get massaged by sound controls.
Even if you DID affect the recorded signals, WHY are you using such exaggerated settings? Or was it by mistake?
In theory, passing the modified output back through the same controls (set to Minimum this time) would undo most of the unwanted effect. Assuming their precise and mirror image for gain and loss.
Aug 23, 2011 | Yamaha AX-396 Amplifier
What is the best Treble and Bass setting on the Yamaha 396 Amplifier for balanced tonal quality?
Set them both to a neutral position (straigth up?). If this sounds good to you, let it stay like this.
Jun 23, 2011 | Yamaha AX-396 Amplifier
My Amplifier YAMAHA DSP A-2 not working remote controler befo time to time worked but now completley dost not work
Is the remote the fault or the machine. I would try new batteries I know this is obvious but even new batteries can be faulty. One way to check if remote is sending out a signal is to use it near a radio on mw it will cause interference, check battery terminals are clean and not had caroded batteries inside. not much more you can do if none of the buttons work but change the remote, you can probably get one on the internet ,
pete
Nov 09, 2010 | Yamaha AX-396 Amplifier
I have a yamaha AX396 amp. . I want to connect my DENON POA2200 power amp. . .How to do it??
Does this model (yamaha) have "pre-out" connectors on the back panel?
If so, use those to go to the Denon
Sep 01, 2010 | Yamaha AX-396 Amplifier
I am trying to locate a mains transformer for a Yamaha AX396. Anyone help please? Numbers on the unit are "Bando" XU443, BO BEM WJ, WJYD53580
Have you tried contacting Yamaha itself?
Or alternativly a Yamaha service center. They might supply you with the part for a fee.
Mar 02, 2010 | Yamaha AX-396 Amplifier
Convert passive speaker to active
You don't say anything about your passive speaker, only thing that I understand you have a Yamaha AX-396 witch have an Power output of 60 watts per channel into 8 ohms (stereo)! That means working great with your passive speaker!!!
Apr 27, 2009 | Yamaha AX-396 Amplifier
Yamaha AX-396 Amplifier Logo
169 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
