Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
WHIRLPOOL TOP LOADER OVERFILLING WATER
I PUT MACHINE ON , WATER STARTS FILLING BUT DOES NOT STOP. THIS MACHINE IS ABOUT 6 YEARS OLD AND IS A COLD AND HOT WATER FEED .
MODEL NO. 3XGSC9455JQ, TYPE 111
  • WASHER111 Jan 20, 2008
    could you tell me how i take off the front panelof the top loader whirlpool. model no. 3xgs9455jq3
  • Anonymous Feb 27, 2008
    My washer is 8 years old. The service repair man told me it is due to lint and debris in the washer tub. This causes the tub to be off balance causing the fill sensor to not work properly. You can't clean the inner tub it will have to be replaced and will cost $371 to fix properly. Needless to say I will be buying a new washer for that price.
  • 51 Answers
While it is filling up try this. Unplug the washer from the wall, if the water still runs then you need to replace the mixing valve. If the water stops then take the screws out at the base of the console and flip the controls back. Look for the clear hose that goes to the water pressure switch and make sure that it is connected. If it is connected take it off the switch and blow through it to see that it is clear of any obstructions.
If this only overfills after the first ore second wash then you may have the slow drain and the drain hose is in the downspout too tight.
Possible items needed;
#1 mixing valve
#2 pressure switch
#3 plumber
Posted on Jan 20, 2008
  • Randy Bell
    Randy Bell Jan 20, 2008
    The two screws are in the back of the endcaps at an angle. remove them and slid the console forward to flip it over.
    I have to sign out now.
    Any more questions, call me at 1-334-347-0000
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Whirlpool top loader agitates when filling up
Nothing, I'm not sure what the problem could be because it does not happen all the time and when it does, it usually fixes itself. M# WTW57ESVW1
your water supply perhaps it is too low pressure ....
so the machine isnt filling fast enough
so check at the machine side of the cold water filler hoze
in the machine end is a filter cone
you need to carefully pull it out with flat nose pliers and clean it
if this doesnt fix it then perhaps the inlet valve is bad...
Feb 07, 2015 | Whirlpool Washing Machines
Washing machine does not stop filling with water and overflows ge top loader wlsr2000g3ww model number
The water fill valve (the plastic thing that the hot and cold hoses go to) has an obstruction (piece of rust or minerals from the plumbing) and the valve won't fully close. A speck in the right place is enough to cause overfilling.
or
The water level switch is defective.
or
The tubing that is attached to the level switch is loose or off. This hose must be tight on the fittings.
Mar 09, 2011 | GE Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My washing machine has had a high-pitched noise when it fills with cold water ever since we moved to a new house. This doesn't happen when it is filling with hot (or even warm) water. We've tried turning...
Are you sure you have the hot pipe on the hot inlet and the cold on the cold inlet ie red to red black to black (easily done), please check carefully. if OK then I think you have picked up some dirt in the inlet filter and this will need to be removed and cleaned,remove lid and follow pipes inside to plastic tank at top near drawer, filter housing can be seen there.
Aug 24, 2009 | Whirlpool Washing Machines
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Jun 09, 2008 | Whirlpool LSR5132PQ Top Load Washer
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
134 people viewed this question
Dan Webster
Dan Webster
Sal De
