Question about Pioneer Car Audio & Video
Guys i have a problem on my pioneer deh-50ub that i put a vide 12'' subwoofer with amplifier and it wos working good for 10 minutes and after theat just comed to silence... i mean the rca plugs that connects with the amp are not working enymore. what can i do to fix it if... i made the connectivity properly, i'm a technician and i know what em i doing. after the RCA went to silence i put the signal from the spekers and steel work but i dont want to connect my amp from the spekers becouse i want hi fi in my alfa not distortsions. it is sommething wrong with my pionner and the question comes now. is there eny setting in the stereo to activate and deactivate the rca ? or is a common thing to thease cd radio player's? pls help i dont know were to ask:D
  • iancovm Dec 11, 2009
    in that case you are tellime that my sony have about six preampf????? :| the way i know the module is ..
    source/filters/preamp/amp. and i know that it;s a four channel cd player.. and my pioneer is working as normal. exept the rca. i steel bealive sommething inside is broken becouse i put the measureing instrument on ohm on 20 kohm and nothing.... infinite... i bealive someware it got to be a fuse or sommething similar:| i bealive i will do the test that you toldme and after that i i'm forced to go inside and openit properly and obvious fixit:| thks for iddea:) GJ
I've got the same problem you have but mine worked for a couple months and then when I was switching the amps, worked for another 30min and then they went silent. I still didn't open it yet but surely it's some kind of fuse that broke. Got to find the shematics of it to do some search here might be the problem...
Posted on Dec 17, 2012
  • 15,935 Answers
Your pre-amp output has failed.
it will require repair.
use your voltmeter and measure the voltage from the RCAs.... it should be approx. 2.5v
If nothing - it is in need of repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 11, 2009
Kicker dx 250.1 class d monoblock amp has a fixed lpf at 80 hz 24db octave non adjustable. My car stereo is a pioneer deh-x55hd with the sub control set at 100 hz -6 slope unable to turn sub control off to...
Do you have the subwoofer amp connected to the pioneer thru pre amp connections; pre amp output of pioneer to pre amp input of Kicker amp. Page 10 of the manual explains how to adjust the subwoofer output. You can select the cutoff freq. that will pass to the subwoofer; The slopes don't match perfectly, but if you use the -12 slope , it should work fine.
Cut-off frequency:
50HZ
63HZ
80HZ same as kicker cut in freq
100HZ
125HZ
160HZ
200HZ
Output level:
24
to
+6
Slope level:
6
12
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X5500HD_OwnersManual112712.pdf
May 19, 2014 | Car Audio & Video
Am looking for pioneer deh 50ub front panel
Its a face for a stereo--posted in wrong area to get a real answer--try (I see you have looked online) to contact them directly to see if even available--tricky issue here is if they suspect it is stolen no help or part.
Apr 17, 2012 | Pioneer Televison & Video
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
this is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
May 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I have a pioneer car stereo after a battery switch my amp gets power, but my subwoofers don't work
is the light on the amplifier on. is your remote wire the blue wire with power. if not you have a remote problem but if it all works check your rca's on the radio or your amplifier.
Jul 29, 2009 | Pioneer DEH-P690UB CD Player
Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pioneer DEH-50UB
Hi again,
Appreciate the direct "Ask Me".
Let's try a process of elimination based on:
  • the Pioneer DEH-50UB is working OK other than it displays error communicating with the iPod at certain times (intermittent);
  • the iPod when played alone/by itself does not exhibit any freezing/hanging problems;
  • the iPod to DEH-50UB connector/cable CD-IU50 is in good working order since if it is not, then the iPod would not even be heard on the Pioneer;
  • the Pioneer's wiring are OK otherwise it would not be working.
Which leaves us the possibilities of:
  • corroded/dirty USB port/interface on the Pioneer DEH-50UB;
  • loose USB port on the DEH-50UB;
  • loose or corroded terminals on the CD-IU50;
  • corroded/dirty contacts on the iPod;
  • RF interference from communications equipment such as CB radios, 2mtr Amateur, mobile phones;
  • electrical interference/noise from the vehicle such as horn relay, A/C relay, fan relay, alternator;
  • electronic noise from navigation/GPS mobile equipment;
  • keyless/remote alarm/security system.
Additional actions that could be explored/done:
  • installation of choke/filter capacitor along the red & yellow wiring of the DEH-50UB;
  • additional grounding/groundstrap of the DEH-50UB to the chassis/metal/body of the vehicle.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 12, 2008 | Car Audio & Video
On my pioneer DEH-50UB the error message 'ERROR 19' is constantly appearing, this is addressed in the mannual however it merley advices you to restart the unit. obviously this is not satisfactory when it...
To my knowledge, ERROR 19 on a Pioneer DEH series indicates failure on the USB connection. This is usually reserve for an iPod direct connection. If you are using such a device, pls:
  • check the Pioneer CD-IU50 USB Interface Cable;
  • reset the iPod;
  • disconnect the iPod and try again;
  • reset the Pioneer by removing the yellow and red connections. Pls note that some versions would require a security code when reconnected. Pls have this ready if and when your particular unit has a security/anti-theft feature;
  • reference page 32 of the manual.
Nov 09, 2008 | Pioneer Car Audio & Video
RCA Problem
You need an active subwoofer input in your amplifier.Which amplifier you are using? Only latest pioneer amplifiers has active sub input and sub output which can be connected to subwoofer.If you dont have active input then you will have to connect it the way you did in old player.
Feb 10, 2007 | Pioneer DEH-1800 CD Player
Car Audio & Video Logo
154 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
