Question about Desa International CCL3018N 18KBTU VNTFRE GAS LOG Heater
DESA free vent gas log system pilot lights won't stay lit. I can relight and unit will fire for appox. 3-5 mins then shut off and pilot is out again
    Problem Solver:
  • 10 Answers
Call 1-800-totalchimney they will assist
Posted on Dec 11, 2009
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
I HAVE A VERMONT CASTINGS RADIANCE HEATER MY PILOT LIGHT WONT STAY LIT I HEAR THE THERMOCOUPLER TRIP THE VALVE BUT THE FLAME WILL GO OUT
We had this problem and struggled with it for over a year. We finally hired someone to come in and service the stove he cleaned everything and blew a piece of crud from the pilot line. NO Problem for 2 years since.
He told me the pilot light should look strong pointed like a pencil not curved up like a candle. He removed the pilot and disassembleed the line and used compressed air.
Jan 08, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
Pilot on logs won't stay lit
Hold pilot button longer. if this doesn't work your Thermopile has gone bad and will not generate enough Millivolts to keep gas valve pilot open. A new thermopile will generate 750 millivolts. It cost less than $20 dollars but is difficult to replace. You should call a certified technician. They will charge you about $100.00
Oct 19, 2009 | Desa International Wall/Window Air...
My vent free Desa natural log will run for a short
it is likely you have dirty O2sensor, it is incorporated into pilot assembly.turn unit off,use compressed air in a can and blow into spot where pilot flames comes from.this will fix it in most cases.in a small % of time entire pilot assembly needs to be taken apart and cleaned
Jun 25, 2009 | Desa International Unvented Gas Space...
Gas log will not stay lit for more than 5 minutes
Sounds like the gas regulator has failed.
There will be sufficient gas flow to light the pilot and get a flame prove, then the main burner lights, you will probably see the pilot flame reduce somewhat, and no longer fully surround the flame prove sensor.
When the unit is relighted, the complete sequence starts all over again.
Have the gas regulator checked and adjusted (if adjustable) or replaced by a qualified technician.
Jan 20, 2009 | Heating & Cooling
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
354 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
