Question about ASUS P4S800-MX Motherboard
Lock the mouse cursor - ASUS P4S800-MX Motherboard
  • 24 Answers
Set it up by going the control panel.
Posted on Dec 23, 2009
  • 37 Answers
Change the mouse. if u already did. problem in ps2 port. so use usb mouse and check it is working or not.
Posted on Dec 11, 2009
How do I get the mouse to moce the cursor?
first go to control panel and select appearence and personalization
go to ease and access center then go to turn on easy access key and select turn on mouse key
then press Alt+left Shift+Num Lock and then use num pad like this
Oct 02, 2014 | Computers & Internet
My cursor on my HP doesn't work. don't want to use a mouse.
i'm sure that there's a button to lock the trackpad,it's near the panel.you need to press it once again to turn the panel on
I think it's right above the trackpad
or look on your laptops keyboard for a picture like trackpad press it with the function Fn button at the same time
or it should be the hardware
the trackpad cable maybe doesn't installed properly,not locked or something
Aug 20, 2012 | Computers & Internet
My cursor won't move
Press F3 It should have a keypad emblem with an x across it.
May 28, 2012 | Apevia Computers & Internet
De activating num lock key only enables cursor movement in four directions. how do you get the number pad to enter numbers?
This is a Windows feature called "mouse keys", it can be disabled by using the shortcut left-alt+left-shift+num lock.
In Windows 7 mouse keys settings can be found by following Control Panel\All Control Panel Items\Ease of Access Center\Set up Mouse Keys
Nov 07, 2010 | Logitech Classic 200 DH968019 Keyboard
On my toshiba mini laptop the cursor gets stuck in a page up and down mode - just goes up and down but won't move right or left. I may have hit some key, but how do I get out of it?
You have Scroll Lock on.
Look at the top of the keyboard for a key which says "Scr Lock" on it and press that key.
the Scroll lock will then be removed allowing you to use the mouse cursor properly.
Regards.
Jul 04, 2010 | Toshiba Computers & Internet
Cursor jumping, pages scrolling on own
bad mouse action , no other words need be said just that.
NO OP SYS STATED BY YOU< XP?
if the mouse is a wireless mouse, the battery is dead.
if the 1 mouse is wired it is bad.
if there are 2 mice connected , shut one down 2mice not allowed.
if the mouse pad is enabled then that is 2 mice if usb mouse used.
and not ever good to do that,
disable one of the mice. (easy no? rules)
i disable my LT here, , in control panel, device manager , mouse pad synaptic or what ever it is.
RC right click disable, it , I hate mice pads././/
Feb 28, 2017 | Compaq NX9005 (dk993ar) PC Notebook
Mouse laptop not working
Touchpads have a cursor lock that suspend the use of the touch pad but allow you to use a mouse. Ensure that the cursor lock is not on. That lock is a thin strip just about the touch pad. Usually, it will light up when it's turned on. If you have that lock in the off position then I would not recommed that you go probing inside your laptop to relsove this issue. You should take your laptop to a qualified tech for repair. That laptop has to be disassemble to resolve any physical problem with the touch pad. You will overwhelm yourself with all the little pieces of computer parts and create a larger and more costly problem for yourself.
Hope dis is helpful...
Aug 07, 2009 | Acer Computers & Internet
Dell wireless mouse cursor froze in middle of screen.
Hi, my cursor had frozen on my screen after my grand daughter pressing something. After trying everything I decided to take it to a local computer shop, it was fixed in seconds. He held the arrow tab(below the caps lock tab) and then pressed F9 it worked!!
Hope this will fix your problem
Jul 27, 2009 | Logitech 3-Button Cordless Optical Scroll...
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
ASUS P4S800-MX Motherboard Logo
43 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
