Question about Leica Digilux 2 Digital Camera
Loss of function
I had owned my Leica for just under 12 months when I discovered that the function buttons on the back of the camera had ceased to operate. I have approached two registered Leica dealers and there solution is to send it back to Germany; no explanation of the loss of function was given. The camera still takes pictures and stores them on the memory card; however, stored pictures cannot be accessed without the use of a computer. At present, what is a fairly expensive digital camera is operating as a wet film camera with an unreliable light meter. Any one else reported this problem? Any solutions?
    Genius:
  • 2,985 Answers
Whilst it is still under warranty you must return it to the seller.
That is your first move - it is their responsibility.
The second is to contact the makers support site and tell them.
Bear in mind price /value not withstanding small electronic devices are replaced not repaired.
Posted on Jan 20, 2008
The lcd screen on my Dlux-4 Leica will not light up at all? any thoughts?
Did you try to press the display button (bottom rich, under the display) several times? The pressing will cycle through different settings, like display off.
Jun 16, 2014 | Leica D-Lux 4 Digital Camera
I own a Leica DIGILUX 1. Problem:Direction pad not working. Other controls like Display, menu, view set also not functioning. Camera can still take high quality pictures.
there is problem with key switches may be there is some due or some water drop goes in side. check by opening your camera if you find then clean it.see what hapen if still problem need to replace key switches.
Oct 18, 2010 | Leica Cameras
The metering of my M8 is always over 1 2/3 stop, any way to make the adjustment? or have to send it back to Leica?
Leicas are norrmally quite good on metering (within the confines of spot metering).
Have you checked whether any exposure compensation has already been programmed in? I don't think it resets itself, so if its consistently 5/3 of a stop out, then it might be that.
Page 107 of the user manual shows how to adjust / check..
Manual is here:
http://uk.leica-camera.com/photography/m_system/m8/download-121_2.html
If its not that, you could use that function as a short term measure to consistently change the exposure.
You don't say how old it is.... if its still under warranty (actually, even if it isn't but its still reasonably new) I'd be tempted to correspond with Leica directly (write first - they respond quite quickly) to establish what they think the problem and solution should be. The 8 went to 8.2 quite quickly (by Leica standards), so its always worth an initital sounding out (which costs nothing). If it is their fault, they'll instruct you what to do next.
Mar 01, 2010 | Leica M8 Digital Camera
Where can I get various problems with my Leica C11 repaired or overhauled? Basically, it need a new rubberized back panel (chemical damage?) and the zoom is sluggish or stuck much of the time. I love this...
Hi David, thanks for the extra info.
In that case, the best place by far for your particular camera is Leica's own service centre in Germany.
The C11 sold in such tiny numbers for such a brief time that even Leica themselves may have trouble replacing the rubberised back panel with an original part, but if anyone does have the ability to locate the part it's them. The other problem is that the original part was clearly an unstable compound, so spares may have degraded as well or may soon start to degrade once fitted to your camera. Leica would normally have revised this part once they were aware, but as there are so few C11's in existence the retooling costs would be uneconomical to remanufacture the part.
Good luck, and I sincerely hope that I'm proved wrong!.
Jan 30, 2010 | Leica C11 APS Point and Shoot Camera
Button stuck, casuing unrepsonsiveness in all other buttons
Most buttons on a camera are a simple raised rubber pad over a printed circuit board. The button gets pressed, a concuctive material on the bottom of the rubber pad puts a short across a printed pad. If the camera senses a short across the down button, it will ignore all other buttons. You need to take the back off the camera and the rubber button pad will probably be right in the back, clean the contact with an alcohol Qtip and you should be OK.
Nov 23, 2008 | Leica D-lux 3 Digital Camera
Leica dlux3
I had the same issue. Unfortunately the camera had to go back to Leica for a new LCD screen. Mine was still under warranty -if yours is take it back asap bfore thewarranty runs out! If it isn't take it back to dealer and argue for a free repair as it's a known issue with the camera- Leica have had alot of these camers come back so you may have some luck with them. Worth trying anyway! Shame as it's a great camera otherwise...
May 27, 2008 | Leica D-lux 3 Digital Camera
Leica Digilux 2
The same problem, no idea how to fix it.
Oct 06, 2007 | Leica Digilux 2 Digital Camera
Digilux 2 problem
No solution- Humidity and moisture is death to Digital Cameras
Sep 28, 2007 | Leica Digilux 2 Digital Camera
No picture thru viewfinder or monitor
Okay, I have found the solution (along with Megant, it appears.) It is definitely a dead sensor issue. I contacted Leica via email (cs@leica-camera.com) and received a response from JoAnn Scott, a Leica customer service manager (joann.scott@leicacamerausa.com) stating that the sensor issue is a common one and is covered under an extended warranty. I shipped my Digilux 2 to this address:
Leica Camera Inc. / Customer Service Manager
Re: Dead Sensor Repair
1 Pearl Court, Unit A / Allendale, NJ 07401 / USA
and within 2 weeks received a repair ticket from Leica, identifying the issue and indicating a zero balance for the repair. A follow up with JoAnn revealed that the turnaround time on the repair would be 4 to 6 weeks. The most expensive part of this whole deal was the 18 dollars I spent insuring the camera when I sent it back via the USPS.
Hope this helps.
Feb 02, 2007 | Leica Digilux 2 Digital Camera
Leica Digilux 2 Digital Camera Logo
98 people viewed this question
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
xalint1
xalint1
Are you a Leica Camera Expert? Answer questions, earn points and help others
