Question about LG KU990 Viewty
When plugged into charger and still turned on phone constantly beeps. Battery signal shows charging and when turned off does not beep
  • sakss69127 Dec 16, 2009
    tried different charger. Same problem.
    Shouldn;t the battery last longer than 10 - 12 months ??? Expensive fix ?
  • 14 Answers
SOURCE: LG KS20 Battery Level Issue
...so guys, after one week of investigation I finally managed to fix this annoying issue. I made an update of the ROM - I had the German unbranded version 10a and I flashed it with the English (Turkey) version 10d (issued in May 08) and to my surprise, the battery indicator started to work properly. For more detail how to flash your device follow the link below (of course you must know what you do so read it carefully because you will do it on your own risk)
Another solution is to send the device to LG / distributor as a warranty repair, they will probably replace your battery. Few users posted that they have done it this way and it also helped.
Here you can find all necessary to flash your device with new ROM version:
http://forum.xda-developers.com/showthread.php?t=405945
Netopjer
Posted on Oct 04, 2008
  • 14 Answers
SOURCE: Lg Viewty wont charge, wont start
try with a new battery your could have give up
Posted on May 27, 2009
SOURCE: lg ku990 won't turn on
I had the same problem at around christmas time when i got the phone, i took it back to the store after alot of googleing and charging the battery. The store said i have to swap it for another one, so i did, and now the new one is doing the exact same thing, definatly not buying another LG phone!
Posted on Jun 01, 2009
SOURCE: LG VIEWTY WON'T CHARGE PROPERLY
I've almost thrown my phone out of the window because of this problem. I really need a solution, I tried changing my charger and cleaning out the socket where it goes in but nothing works. it Just keeps beeping and beeping. This isnt really a solution, more of an agreement of how annoying this is!!
Posted on Oct 01, 2009
SOURCE: hi my lg viewty keeps beeping whilst charging what
same, for me it was a dodgy charger
Posted on Mar 29, 2010
If the batteries needed changing would the green charging light still come on and would the alarm beep when attached to scooter and turned on?
Yup. The alarm beeps if you have the charger plugged in and turn on the key even if the battery is flat. The charger won't bring a totally discharged battery up to full charge. You can charge the battery individually using an automotive style battery charger. The charger should NOT be the automatic type. It may take some time to recover a flat battery. Charge it until you can see at least 10 volts on the battery. The scooter charger can then finish up the charge. If after you go through all this and the batteries will not take a charge, then it's battery time.
Nov 20, 2015 | Health & Beauty
Samsung admire shuts off on its own reads 0% when its fully charged
try to buy original battery and original charger, then try again, if problem persist show some oficial repairer maybe it is a charging ic problem due to waterdamage.for further help post comments.
Jun 28, 2012 | Samsung Admire SCH
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Mar 03, 2011 | Plantronics CS60 Professional Headset
Motorola razr v3 wont charge, the bettery is not that old the phone beeped to signal charge requred, plugged it in as usual but cant turn it back on.
If the charger is plugged in, the phone is hooked to it, and it still will not come on, I would think it's a charger or electrical outlet problem.  I think most phones will bypass the battery power if they are plugged into an outlet, so try another wall plug, and if that wasn't it, try a different charger.  If a different outlet and charger don't solve it, it may be time to take it to the store to be checked.
May 29, 2009 | Motorola Mobility RAZR V3
LG chocolate phone/low battery/plugged in/constant beeps
take your battery out & rub on the pins of battery. then put it in the cell phone & switch it on & charge it.
Dec 20, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Charging
It's beeping because the battery is completely dead and needs to charge. If beeping doesn't stop after a while of charging, you may need a new battery or a new charger.
Jul 21, 2008 | Motorola Mobility RAZR V3
V262 constantly beeps "low battery" alert
your battery might need to be changed. even if it has a full charger it might not be able to properly charge you phone.
try a new battery.
Mar 06, 2008 | Motorola Mobility V262
Cell phone`
Your battery has had it. You can get a new online for only a few dollars. From what I've seen from alot of the Razr phones the beeping it as just as you were saying. When the battery is dead or does not have enough power to do the basic functions it will beep. The only difference is that, even if it is turned off they will still beep because it has a low battery. have you tried a different battery.
Jan 21, 2008 | Motorola Mobility RAZR V3
SGH E900 charging problem
if th emobile is under warrenty contact ur retailer.
Jan 10, 2008 | Samsung SGH-E900 Cellular Phone
LG KU990 Viewty Logo
110 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
