Question about Cell Phones
Need a manual for Nokia N-99i as I would like to change background in the message area as it is hard to read messages with the dark brown background with lines and dots.
Hard to read
Tablest have different screen cofig parameters. Look for it in your Setting menu item.
Apr 24, 2015 | Tablets & eReaders
Phone says messages, but don't know where to look
without knowing the model of phone its going to be hard for anyone to help, in saying that try deleting some old messages , maybe the model you have can only show so many at a time and your message box is full.
Or if you problem is you dont know where to look to see any messages at all...your problem isnt with the phone. you just need to read the instruction manual
Jan 09, 2014 | Nokia Lands Phones
How do i change the colour setting . When i recieve a message . Am not able to read who its from. The lettering is to small . And the wrong colour
Rather than explaining the details , i'll give you the site which gives you the details to change your theme so that you can set an appropriate background which makes your fonts visble http://www.pakblogger.com/how-to-set-change-theme-on-nokia-5800-xpressmusic
and also you check out this to change the font http://ignati.com/tips-how-to-change-font-in-nokia-5800-xm/
Thanks and have a great time with your mobile. Please vote if helpful
Oct 10, 2010 | Nokia 5800 XpressMusic Smartphone
Font color editor for nokia n70
generally you cant change the fonts.. the better thing to do is use the default nokia theme which wil be in blue color..
Mar 24, 2010 | Nokia N70 Cellular Phone
I am unable to send text messages in nokia 5230 w. when i tried to send my first text message it asked me to enter message centre number but i entered any random digits after that i cant send any msgs
I am unable to see new messages on my nokia 5230 until i go into the message center manually. How can i correct the settings so i will have an indicator to inform of new message
Mar 21, 2010 | Nokia 5230 Cell Phone
Screen is white when on.....
Try disconnecting your connection to your computer.
If you see a no signal message with a dark background, you have problems with your video card.
If you continue to recv. the white screen, you have input signal problems with the LCD monitor itself.
If you do recv. a no signal message witha dark background, try removing and reseating the video card.
Oct 24, 2009 | ViewSonic VX2235wm LCD Monitor
Inverted screen of my cellphone
unfortunately, there is no simple answer to this, the only solution is to take apart the phone, and reverse the wiring... which will usually be in a bracket... if it is, you should just be able to flip it, if not, you are gonna need a solder gun to create a hard bypass from the wire to the screen, either way, you have to reverse the wiring and this should fix the problem! hope this helps!
Oct 11, 2009 | Cell Phones
My nokia 6120 classic has text so small i can hardly read it and its alreadt set to large.
change the message settigns
go to options as follows
mesage>message settings> font size > large
Jul 16, 2009 | Nokia N73 Cellular Phone
I have saved the picture message by mistake received instead of delete.Now how to delete the picute saved in my mobile screen .my phone is samsung
What do you mean by "saved on screen"?
is it set as your wallpaper/background/standby picture(call it anyhow)? to change that you have to go to settings and look for display and background etc. (read the * manual)
is it saved in the phone's memory? go to stg like GALLERY in the phone or a file system explorer and there just find the file and delete it. (the manual could be of great help in this case, too.)
Apr 14, 2009 | Nokia N95 Cellular Phone
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
