Question about Pool & Spa
Can not clear FLC error....tried cleaning filter and resetting power source but still has error
  • 10,515 Answers
FLC Refers to Flow Error.As per Manual, you need to follow the below :-
~ Open Bleed Valve to Release Trapped Air.
~ Adjust Pressure Switch.
If problem persists, Take a Voltmeter / Multimeter and Check Pressure Switch. More often, Pressure Switch is the main reason for this.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 11, 2009
Leisure Bay -My spa will not heat - no FLC/FLO code/Voltage is correct/4KW Dry Element Heater test 15.9 Ohm across leads and OL on each to housing
It appears per your test that the heater May not be the problem as it shows that it may be good.
Your error message is a Flow condition / Restriction
Try cleaning the filter
Nov 09, 2014 | Pool & Spa
Flc error
mine gave me issues if I didn`t fill the tube to the right level. also I unplugged it for 20 minutes and when plugged back in worked fine again. Go figure.
Apr 21, 2014 | Garden
Flc trouble code
Did you try to unplug it and then after a hour try to plug it back in and see if it set it's self, or call the manufactor for the code or the company.
Jan 04, 2013 | Arctic Pool & Spa
My fontloader samsung wassingmachene p843 giv me and error code e3 4e and5e
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 22, 2012 | Washing Machines
"clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Mar 14, 2011 | ViewSonic PJ501 Multimedia Projector
Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Aug 05, 2009 | Office Equipment & Supplies
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
C5180 Ink System Failure CodeOxc18a0206
Here is what you can try:
1. Turn off the power and unplug it from power source.
2. Open the right side of the printer (looking at the front).
3. Disconnect, by pulling gently, both white flat ribbon cables off the main circuit board.
4. Plug in the power source and turn the printer on. Wait till you get a error message and push "OK".
5. Unplug the power source.
6. Reconnect the flat ribbon cables by aligning and carefully pushing them into the conectors on the main circuit board.
7. Plug in the power source and turn the printer on (Printer preparing occurred).
8. The 0xc18a0306 error should now be gone.
http://www.fixya.com/support/t5587774-hp_photosmart_c5180_ink_system_failed
Feb 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error 5400
the 5400 error is telling you there was excessive temperature in the printhead, and this error code will stop all printing attempts.
Unplug the power from the printer and leave it off for a hour and then check the pins inside the carriage and clean them and clean the contacts on the back of the head.
May 31, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Pool & Spa Logo
458 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
