I have a 5year Old F1245W, recently it developed a burnining electrical smell during the cycle, now It will aggitate the washing but wont spin or drain, even if you advance the programme, I now have a machine full of water and washing and I cant get it to drain.
What you do mate is make sure off,take out the drain pipe from the back.,lay down drain pipe flat to the floor as possible..i use a paint roller tray to drain in to..have a bucke t near by 2 put excess water in..hold up drain pipe whilse doing so,repeat untill drained as much as..then lock will release..set program back 2 spin if working.should work for you!
Posted on Nov 17, 2012
Check the drainpump. It could be burned og blocked.
Posted on Jan 25, 2008
May 18, 2014 | Zanussi Washing Machines
Feb 26, 2013 | Zanussi F1245W Front Load Washer
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance.
Daniel
Aug 16, 2011 | Zanussi F1245W Front Load Washer
Sep 05, 2010 | Zanussi F1245W Front Load Washer
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Nov 16, 2008 | Washing Machines
Jun 29, 2008 | Zanussi F1245W Front Load Washer
Nov 29, 2007 | Zanussi F1245W Front Load Washer
Jul 12, 2007 | Zanussi F1245W Front Load Washer
Mar 30, 2007 | Zanussi F1245W Front Load Washer
219 people viewed this question
I have the same problem, and I have put a new water pump in as it was burned out. Now it is still showing E20 and will not fill!
product will not drain or spin but have not noticed a buring smell
