Question about Konica Minolta Office Equipment & Supplies
Minolta Bizhub C253 - C-11C3 finisher error
Minolta Bizhub C253 - C-11C3 error has to do with finisher but not even the tech seems to know what the error means. Have tried trouble reset, disconnecting hole punch. Unit works fine with finisher disconnected.
thanks!
Tina
  • mdcitrus Dec 12, 2009
    Have tried this already. With finisher removed the copier runs and prints fine with no error codes. Minolta was contacted directly and they do not have a definition of this code other than it is "finisher" issue.... still working on it.
  • 4 Answers
Is has something to do with rejection paper on exit finisher or punch unit.maybe it's just a little white thing on finisher tray that pushes the paper out,often ripped out by the users or mounted incorrectly.or less correctly punch unit is badly and need to unplugged from the finisher unit.
Posted on Jul 11, 2012
  • Konica Minolta Master
  • 1,297 Answers
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Posted on Dec 11, 2009
Error code c-fe03 in konica minolta BIZHUB C-451 ?
MFP board issue might have a tech re flash the firmware
May 12, 2015 | Konica Minolta Bizhub C451...
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Code error 1190
• The CD Aligning Home Position Sensor (PC9-FN) does not go
LOW even after the lapse of a given period of time after M5-FN
has been energized (to return the Aligning Plate to its home
position). Serious finisher issue to complex over the internet have a tech come out
Jan 06, 2014 | Konica Minolta bizhub C250 All-In-One...
Minolta bizhub c451 error code c- 11b0
Stapler in side the finisher is not moving correctly open the finisher a bring the stapler to replace staple cartridge position. If you can if not get a tech to look at it.
Nov 25, 2013 | Minolta Office Equipment & Supplies
Bizhub 350 error code C11AO
Paper Lift failure of the finisher output tray. Did some one hit the finisher tray or did it hit something underneath? May require resetting the position of the finisher output tray, get qualified tech to do it !!!!.
Oct 15, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
Mar 21, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub c-353 has an error code c-1183 which will not clear for me It's Saturday and I have a HUGE project with lots of people coming to help.
The finisher output trays hit something like a trash can or boxes stored under the trays. to fix must remove the rear of the finisher reset the elevation drive assy. Be careful don't let the trays fall down tech would be good on this project
Nov 01, 2008 | Minolta Office Equipment & Supplies
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
525 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
