Question about Maytag SDE5401AYW Electric Dryer
The plastic connector where my dryer broke where the electrical cord connects to dryer. How do I replace it?
  • 112 Answers
Remove the two screws in the middle of it. you may have to lift the top of the machine off
Posted on Dec 11, 2009
Sears model 1150 snow thrower how repairing the electric connecter for sears model 1150 snow thrower
It's just a simple AC pronged piece. You can buy the actual piece from Sears OR you can buy an Electric Line-cord and wire it into teh plastic box where the Push button 'Start ' switch is.
Mar 01, 2015 | Garden
LG Ground terminal block wire exploded. Need to replace entire harness and 4-prong power cord. Do I really need to replace the entire harness or can I buy a new terminal block and cut the black grounding...
you can buy a new block and you don't have to replace the whole harness if the wire just burnt at the block,you can cut it,put on another wire connector and reconnect it to the block with the cord,make sure when you're done all the nuts and connectors are tight so this doesn't happen again and use the metal cord bracket,if it's not on your cord buy one,it holds the cord in place so when the dryer moves it holds the cord in place,if you don't use it the cord could cut on the metal frame and the wire connectors on the block will come loose from the cord moving or vibrating with the dryer running
Feb 24, 2018 | LG DLE2101 Electric Dryer
Whirlpool electric dryer wont run. the light comes on when the door is opened so there is electricity running to the dryer
check the door switch to see if it's broke,then check to see if you have 240 volts going to the dryer inthe back where the cord connects to it and also i need the model number
Sep 21, 2013 | Fisher and Paykel DEGX1 Electric Dryer
I have a whirlpool inglis dryer that is about 5 years older and I have a 3 prong electrical cord, in the back of the dry were the electrical cable connects into the dryer (There is 3 connection locations)...
Hi johnebrenner...
Most likely cause of the wire being burned is a loose and arching connection.
I would recommend that you replace your existing cord and wire with new ones and make sure to tighten your connections very tight, but do not strip the screws by over tighting..
Please take time to rate me
Aug 23, 2011 | Whirlpool Inglis IP8200 Dryer
I need to convert a 3 prong dryer cord to a 4 prong
Hi. Ok, with the rear terminal block cover open, you will see three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nut driver to remove the nuts or a Phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Next, you need to disconnect the bonding jumper on your dryer. The bonding jumper is either a metallic strap (typically copper or copper clad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame. If you removed a ground wire instead of a bonding strap from the neutral terminal, you need to connect this ground wire to your dryer’s frame. Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. Now,to hook up your new 4-wire dryer cord, connect each wire to the dryer’s terminal block matching color for color (white to white, black to black and red to red). Connect the green wire to the green ground screw on your dryer’s frame. Once the wires are connected, simply recover the space, and secure the cove with the screw provided.
Aug 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune MDE5500AY Electric Dryer: electrical hook up...
If this dryer doesn't have a cord, you need to go to hardware store for a dryer cord, usually 4 wires 30 amp. the black and the red wires connect to the 2 brass screws with red and black wires already on the other side of the terminals. (oh, you should use a strain relief connector to run thru the knock out (hole) for the cable. The white wire connects to silver screw, which should have a white wire on the inside connection. Now the green wire connects to the green terminal, if there is one, or any other screw that should be marked as ground on the inside somewhere.
This should do it unless you don't have the dryer receptacles wired in yet.
May 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
CHANGING DRYER CORD
All you need to do is, attach the middle connection from the cord to the middle post on the dryer. The 2 outside connections on the cord will attach to the outside posts on the dryer. It does not matter on the outside connectors as far as which side they go.
Make sure they are fastened down tight. If the connections are loose at all, they will go bad.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Where to wire the ground when changing a three prong to a four pr
This cover is all different sizes and shapes depending on the manufacturer of the dryer, but it is typically very close to where the cord enters the dryer. The cover is typically held in place with 1 - 4 screws. See image to the right of a Maytag Performa dryer access panel.
04b796a.jpg With the cover open you will see a terminal block with three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nutdriver to remove the nuts or a phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Now you need to install a bonding jumper from the neutral terminal to the dryer’s frame. The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame.
Installing this bonding jumper is an extremely important step when changing from a 4-wire to a 3-wire power cord to prevent electrical shocks when touching anything metallic on your dryer.
If you do not have the original bonding strap, you can make one. You need a short piece of green 10 AWG wire, 2 ring terminals, a pair of wire strippers and a pair of crimpers. Strip both ends of the green 10 AWG wire and crimp one ring terminal onto each end of the wire. Now connect one end of the wire to the neutral (center) terminal and the other end to the dryer’s frame; where your ground is connected now. a9fc1b2.jpg Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. To hook up your new 3-wire dryer cord, connect each wire to the dryer’s terminal block. The 2 outer wires are your “hot” wires and the center wire is the neutral. Replace the access panel cover and your new 3-wire dryer cord is installed Before plugging in your new dryer cord, I recommend turning off the breaker to your dryer receptacle. Then plug in your dryer. Now turn the breaker back on. This is not fool proof, but it is a safer way to turn on the power to your dryer if you made a mistake connecting your new dryer cord.
If your dryer is different from the one described above and would like a second opinion on your connections, email a picture of the terminal block to info at ezdiyelectricity dot com. I will post the pictures on this page to help others with the same dryer.
Apr 05, 2009 | Whirlpool LER4634J Electric Dryer
What type of powercord and outlet does this dryer require? Electrician installed a 220 outlet.
ELECTRICAL REQUIREMENTS
ELECTRIC Dryer
CIRCUIT - Individual 30 amp. branch circuit fused with 30
amp. time delay fuses or circuit breakers.
Use separately fused circuits for washers and dryers, and DO
NOT operate a washer and a dryer on the same circuit.
POWER SUPPLY - 3 wire or 4-wire, 240 volt, single phase, 60
Hz, Alternating Current.
POWER SUPPLY CORD KIT - The dryer MUST employ a 3-
conductor power supply cord NEMA 10-30 type SRDT rated at
240 volt AC minimum, 30 amp., with 3 open end spade lug
connectors with upturned ends or closed loop connectors and
marked for use with clothes dryers.
WARNING – Risk of Shock. Appliance grounded to neutral
conductor through a link. Grounding through the neutral link is
prohibited for (1) New branch circuit installations (2) mobile
homes; (3) recreational vehicles; and (4) areas where local codes
do not permit grounding through the neutral, (1) disconnect the
link from the neutral, (2) use grounding terminal or lead to
ground appliance in accordance with local codes and (3) connect
neutral terminal or lead to branch circuit neutral in usual manner
(if the appliance is to be connected by means of a cord kit, use
4-conductor cord for this purpose). USE COPPER CONDUCTOR
ONLY. The dryer MUST employ a 4-conductor power supply
cord NEMA 14-30 type SRDT or ST (as required) rated at 240
volt AC minimum, 30 amp., with 4 open end spade lug
The complete installation manual is at ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134917700es.pdf
Jan 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
4 dryers broke in a row
hi thanks for the question does the dryer keep blowing the fuses after a short time if this is happening the problem is in the fuse box for the dryer .the fuse box has a loose connection . so every time you use the dryer the fuse gets hot & fails . replace the dryer duse box thanks the appliance doc
Sep 28, 2008 | Hotpoint TDC32 Electric Dryer
Maytag SDE5401AYW Electric Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
