Question about Maytag Neptune MDE5500AY Electric Dryer
This is the 3rd time I have had this problem, my Neptune sensor touch pad dryer will not start, it reads 8.8 on the display. If I unplug the unit so that only one side has power (110), when you open the door the interior light will come on and the display will show 50 minutes / you can press the pad which will change the settings. Upon closing the door the display goes blank - no lights. The last two times I had this problem the top panel and circuit board had to be replaced at a cost of $240.00. In fact my washer of the same match has had it's panel replaced twice at the same cost. Is there a defect with this line of product?? Other friends who have the same units have had the same problem and have gotten rid of them. Instead of replacing the panel and circuit board is there a simple solution to what it is, is the repairmen actually correct in replacing the whole unit or can it be fixed.
We have the same Maytag Dryer MDE5500AYW and after reading a few posts of possible fixes--Turn Power Off them back On to reset---Replace Control Board-- Then I saw APPLY HEAT to the panel control area AND IT WORKS. I put a small heater on the dryer top in front of the Control Board Panel Readout and after it warmed up the 88 went out and when I pushed Start It Works.
I think that cold weather has something to do with the problem. In Dallas it is 42 degrees outside and 70 degrees inside But the dryer vent is connected through the outside insulated brick wall and the cold air coming forom the outside vent makes the inside of the dryer COLD until the dryer is in operation.
Long story short--I will keep the heater handy in case It is needed until the weather warms up.
Roger
Posted on Dec 19, 2009
Mine having the same problem, display of 88 and no responding. Using the hair dryer as other tip. It works like a champ for three times. Note that all of this 3 times were in Winter. For this 4th times, which is today, it's Summer. The outside temp is around 100 degree. However, it's still repairable with the hair dryer. I started to worry the thing is getting worse and worse.
Posted on Aug 05, 2010
What does the code F2 mean in the time window of the Whirlpool Cabrio gas dryer and how do I reset the machine?
Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes
  • PF--Power failure
  • AF--Restricted air flow
  • F01--Primary control failure
  • F02--Keypad/User Interface failure
  • F22--Exhaust thermistor open
  • F23--Exhaust thermistor shorted
  • F24--Inlet thermistor open
  • F25--Inlet thermistor shorted
  • F26--Motor drive system failure
  • F28--Moisture sensor open
  • F29--Moisture sensor shorted
  • F30--Restricted air flow
looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
Sep 07, 2012 | Whirlpool Dryers
We moved our neptune dryer to our new cottage and it needed a new hookup. It worked for a while-but now it reads 88 and won't work. Is it the dryer or the electrical?
When the 88 displays, put a heating pad over the display - it will be ready in just a few minutes. Sounds crazy, but it works every time. May take up to 30 or 40 min.
Dec 27, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Problem with my maytag neptune mde7550 dryer will not go through any cycles by useing touch screen and will not switch off by touch screen
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
Oct 17, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Start/pause button not working, is it the control panel or the control electronics board?
First unplug the Dryer and allow about 5 mins to pass, this will allow the board time to reset, plug Dryer back in, if problem is still present, its possible that the touch pad is defective on the dryer, if other functions work when touched, it is the touch pad, and not the Board
May 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer says 8.8. on display
Put a heating pad over the display panel. After 5 - 10 minutes, the display panel will return to normal and the dryer will work,
Jan 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a 10 year old Maytag Nepture MDE5500ay with a membrane control panel. When I touch any button on the membrane it immediately indicates a 8.8. on the display. I have unpluged the machine and waited...
The 8 code generally means a stuck keypad which can only be resolved by replacement of the keypad.
The service manual at the link below will give you some guidance in section 9. Good Luck
MDE5500 Service Manual
Oct 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The lights on the dryer work it wont start it didnt have any problems drying before this happened no odors or smells i have a maytag MDE5500AYW. please help. thank u
If the display on the dryer reads '88' then place a heating pad over the display. After a few minutes, the '88' code will clear, and it will work fine. Sounds crazy, but works every time for me.
Sep 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Can't change dry options...
no try to unplug it got a few minutes if that dosen't work replace the touch pad
Dec 09, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Display
Check your manual. Sound like wrinkle guard setting
Nov 17, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
351 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
