Question about Asrock M266A Motherboard
No appear on the monitor
Change my cpu from p4 2.0Ghz to p4 2.4Ghz,after i change thsres no appear on the monitor.My ram is only 128ddr 266,is my ram is the problem coz 8s only 128mb?
  • 1,067 Answers
In xp yes need 256 mb to start least 1 gb to move nice
Posted on Jan 20, 2008
Power on ok but no display. ram not detect
First disable the onboard VGA then put in a known good AGP graphics card to see if you can get through the POST if your BIOS i rejects the RAM chips it should give you a short series of beeps this would indicate that the memory is not compatible as a rule of thumb PC2700 speed memory is for a motherboard and processor with a 133Mhz FSB this is quaded to 533MHz. you can usually place faster memory but not slower memory look at the table below for rated Frontside Bus Speeds.
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200/PC2700*/PC2100 400/333*/266 MHz (min busspeed 200Mhz)
533 MHz PC2700/PC2100 333/266 MHz (min busspeed 133Mhz)
400 MHz PC2100 266 MHz (min busspeed 100Mhz)
Dec 06, 2010 | Intel KD865GRH 10 Pack (KD865GRHPAK10)...
My Shuttle AV49P motherboard would not bootup. The system is powering up, & the drives are spinning up. There are no beeps & no infor on the monitor. Monitor is working, AGP Graphic card is...
You should get one bios beep. You seemed to have tried everything except a different hard drive. Check the capacitors to see if they busted open. Other than that the motherboard could be fried. Hank
Aug 18, 2010 | Shuttle AV49PN Motherboard
I press power botton but it keeps blinking
disconnect signal cable and give power to monitor and see "no signal check the signal cable" massage appears on screen if so then monitor is ok fault lies in cpu open the cpu disconnest the ram and listen whether contineus beep comes or not if comes then ram is faulty if not then motherboard is faulty
Mar 12, 2010 | Computers & Internet
When I turned on my computer, it said it was in power saving mode and to press any key or move the mouse. Did that. Now I have a black rectangle in the middle of my screen that says, "Positioning,...
Your Problem Is not in your Monitor Its in your CPU. Your CPU is not giving Display Signal to Monitor that's why Monitor goes to power saving mode. try to open Your CPU and remove RAM Clean RAM Slots and Fix it Again. Try to Boot now.
Mar 11, 2010 | Dell E172FPt 17" TFT LCD Flat Panel...
ABIT TH7II -change CPU
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
Apr 09, 2009 | Abit TH7-RAID Motherboard
Cornea CT1700 monitor has no power.
i think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Dec 22, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Asus a8v-x mb installation
Check if it's plugged in(haha just joking :)) )... are you sure the system panel connector from the case fits with ur mothrboard? if not you have to change some wires.Also there might be somehing from the PSU.I hope this worked for you coz it worked for me.
Oct 28, 2008 | ASUS K8V-MX Motherboard
IBM Mother board mlack out
just buy another power supply with a higher power for the problem is not on your computer but on the power supply,then try to plug it in a 220v voltage regulator,but i surely recommend that you'll buy a new power supply ok
Apr 08, 2008 | IBM 486DX 80486 (32G4144) Processor Board
try to check the connections between your monitor and vga port (blue) located at the back panel of your casing. it nothing to do with ram.
Jan 20, 2008 | Asrock M266A Motherboard
Memory installation
Check your manual pg. 11 section 2.5. The 168-pin RAM go in the black slots ONLY. The 184-pin RAM goes in the blue slots only. Worth a check! Luck.
Please vote.....
Jan 18, 2008 | Asrock M266A Motherboard
Asrock M266A Motherboard Logo
74 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
