Question about Canon MP970 Photo All-In-One InkJet Printer
The large black ink tank doesn't deliver at all. I have: cleaned, deep cleaned, downloaded the newest drive from the Canon site, replaced the tank more than once, done the nozzle alignment, replaced the print head, and grumbled a lot. I have Windows Vista, which has been my operating system for 2 years. I get an error message on the printer, but it never tells me what the error is.
  • 5,603 Answers
The error could be that the waste ink is full. They count the number of cleanings and shut down the printer when the waste ink pad gets full.
One can clean the pad by rinsing until it is almost white and then use special software to reset the counter in the printer.
Look up maintenance software for your printer.
One has to disassemble the printer to get at the waste ink blotter.
Posted on Dec 11, 2009
Canon pixma ip1000 black ink stop printing suddenly
Based on your explanation I will try to help.
Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
Aug 11, 2017 | Canon PIXMA iP1000
The black ink keeps drying up and will not print out black print
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 03, 2013 | Canon Cli526 Black Cyan Magenta Yellow 3x...
My large black ink cartridge with not print correctly on my Canon Pixma MP830. All the other colors work fine. I've done numerous cleaning and deep cleaning. Then replaced the cartridge and it still prints...
Are your black ink cartridges genuine Canon ones?
Are the contacts clean when you remove the cartridge?
If not blow off with compressed air and a clean brush, if necessary.
Canon.com's site covers the verification that the cartridges are installed correctly below:
Issue: Black ink does not print
Solution: Confirm that the recommended ink tanks are installed properly MP800R / MP830
Replacing an ink tank When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. Recommended Ink Tanks:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note:
    When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Check the ink tank. If the orange tape is as shown in Figure <1>, it is properly removed. If the tape is not removed (as in figure <2>, pleease remove the extra tape).
  6. Insert the ink tanks into the print head.
    Note:
    Press the mark "PUSH" on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  8. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Jul 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Black ink not printing
Dear Friend, Check & confirm the following will help you...
  • Check ink tank situates Properly
  • OR Install recommended Ink tanks in Perfect Order
  • OR Remove Tape[Confirm there is no Orange tape across the top of ink tank]] From the Ink tank
  • OR Replace Ink tank
  • OR Perform Deep Print Head Cleaning
  • OR The Print Head may Need Replacing
>i860_install_inks_animation Click here
Above picture is the Correct View.... If this helped you,Do rate ME...Thanks For Contacting FixYa....
Apr 22, 2010 | Canon i860 InkJet Photo Printer
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
My canon PIMXA MP780 is not printing from the large Black
The black is the first to wear out on these printheads, you will need a new printhead, QY6-0049-000.
You will only waste inks trying to clean or deep clean, the best bet is to replace the printhead and if all else is ok you will get many more trouble free prints and better quality color prints.
Feb 22, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon IP4300 - the two black ink cartridges
No!
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Don
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Large black ink cartridge won't print
please send me your printer show any signal
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
New Black cartridge not printing
Ink blockage between tank and printhead. Take out colour tanks and clean. with cartridge flushing agent in a spare tank, or do them all at the same time with cartridge flushing liquit.
Feb 11, 2009 | Canon MP520 All-In-One InkJet Photo...
Canon MP970 Photo All-In-One InkJet Printer Logo
195 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
