Question about Euro-Pro Shark GI490 Iron
Don't know if mine is a 448, but my Euro Steam iron just doesn't got hot enough like it used to... useless for ironing. help!!
    Brigadier General:
  • 5,158 Answers
The heater coil in those irons does get worn out as they age. the are basically large resisters (just like those little wires in a toaster). there is a chance that calcium has built up on them caused by the water. add some vinigar to the water you put in the iron and let it sit for a couple hours or overnight if possible. rinse it out and see if that makes a difference.
Posted on Dec 11, 2009
  • Roberta Smith
    Roberta Smith Dec 11, 2009
    another product that would work well that just occured to me is called CLR... you can pick it up at walmart or any auto or hardware store. add some of that to the water chamber and let it sit for about an hour, tho it would likely work faster then that.
    rinse it out, while rinsing it out you should see all the calcium that has built up inside coming out.
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
My shark iron get hot but it will not put out any steam none
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 26, 2009 | Euro-Pro Shark GI490 Iron
I have a Euro-pro iron with a separate tank for producing steam. When heated and in use it will "spit"unexpectedly which makes is rather useless for most projects. Why does it do this? What can I do?
try adding a calcium cleaner (like CLR) and letting the steam run all the way through without ironing and see if it cleans the steam lines and holes
Aug 29, 2009 | Euro-Pro Irons
Euro Pro Steam Iron
I'm having a problem with a Euro Pro Steam Iron as well. Thier customer service phone number is 1-800-798-7398. Hope this helps
May 13, 2009 | Euro-Pro Steam Generator EP8001 Iron
I need some help
heatman101
Jan 21, 2009 | Euro-Pro G6118 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-pro iron steam genarator model # ep8001
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
tombowdb
Now for Sears to try to locate the tool that will open the case.
Apr 17, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Shark GI490 Iron Logo
22 people viewed this question
Top Euro-Pro Irons Experts
Steve Allison
Steve Allison
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
