Question about LG enV VX9900 Cellular Phone
What should i do to make the blue screen go away? its only on the internal screen
There is a blue screen that says " there is no
traci...put a device into the option and the blue screen will go away and message too
Jul 07, 2013 | Televison & Video
A blue line has came up on the screen of my hp laptop and when i put pressure on the back of the screen it goes away how can i make it go away for good?
you wold have to replace the screen , your screen is slightly cracked but not all the way through yet so in a matter of time it will just have the blue line across and not go away
Feb 24, 2010 | HP Compaq nx6110 PC Laptop
My tv has a pink blob in the centre with a blue large ring around
Either someone got too close to it with a magnet or you have an output problem.
Jan 18, 2009 | Panasonic PT-44LCX65 Television
Blue screen
just to the bypass code but if the teh battery is disconncected you have to do it again
Oct 06, 2008 | Jensen VM9510 Car DVD Player
Shows ID:4100
Connect to power supply, turn on, press reset button (under the power button); you will not loose settings. This is all said also in the manual undet reset.
Aug 07, 2008 | JVC eAViNU KV-PX9 GPS Receiver
Blue screen
Are you using component video cables? If so, check that these aren't loose on either end. Next I'd consider that whatever video cable/input might be bad, and switch cable or cable type... i.e. switch from component to HDMI or vice-versa. Then change up the source (cable box versus DVD player). If you're still seeing blue at this point, the TV internals are the bad.
Jul 23, 2008 | Panasonic TH-50PX75U Plasma HDTV
Blue Screen
OK, so I took out the added RAM, changed the internal RAM to a new 1GB stick. The machine booted, windows started, I logged on, then blue screen. I put the old internal RAM back in, changed the hard drive, same result. This test suggests that the RAM is fine as is the hard drive as the blue screen appeared with different hardware. My next step is to replace the motherboard as the appears to be the issue. I'll let you know how I get on.
Jul 17, 2008 | Toshiba Computers & Internet
Blue spots on screen
lol. there is a speaker next to it a big speaker. just move it away! lol. the spots will go away.
Jul 14, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
LG enV VX9900 Cellular Phone Logo
51 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
