Question about Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony 36fg-36fv300 my t.v. of 6 years has now started asking me to continousely do a initial setup. witch as u know it then scrolls through the channels and thats it but won't stop after i have done so it just keeps asking me i have tried taking the plug out for a minute but it just starts up an hour later. will now try the 4 hour hard reset and see any other ideas would be much appreciated
Plug tv directly into the wall and not through the cable box.
Posted on May 04, 2010
Eror code E000020-02a9
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Aug 02, 2013 | Office Equipment & Supplies
How do I change language settings on my Dell V313 printer
Printhead error
Apr 22, 2013 | Dell V313w AllInOne InkJet Printer
Im looking for the master reset
To Perform a Master Clear:
  1. Press the center select key
  2. Scroll to and select Settings (may be Settings & Tools)
  3. Scroll to and select Initial Setup
  4. Scroll to and select Master Clear
  5. If prompted for a Security Code, enter 000000 (or whatever the customer set it to)
  6. Select OK to confirm
To Perform a Master Reset:
  4. Scroll to and select Master Reset
Mar 06, 2011 | Motorola Mobility W490 Cellular Phone
My nephew's original xbox will not turn on it just flashes green and orange around the power button
If your system has had an internal system error (three lights) and is now having issues recognizing controllers, remotes, and/or personal music player's, the only currently know solution is to rerun initial setup.
Rerun initial setup
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the "Initial Setup" option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup.
Resetting to factory defaults / resetting parental locks (unconfirmed)
This was posted on the xbox-scene forums and might work only with older versions of Xbox 360 dashboard.
Press the following key combination
  • Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, Up, Left Bumper, Left Bumper, X
This should give you a dialogue asking whether or not you want to reset your system to factory default settings.
Reset Xbox 360 video settings
While the Xbox 360 is starting up, hold Y and Right trigger. This will cause the system to reboot and reset the video settings.
Nov 21, 2010 | Microsoft Xbox Console
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
I don't know the security code
Scroll through your menu,
enter settings ,
scroll down to initial setup,
scroll down to the last option, you will see master clear..
apply number ' 0' six times,
clear options will be either yes or no..
all formar datas will be cleared..
Feb 09, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Error 405
this usually happen when sending fax ,if thats the case take the following steps
1. Press the setup button (upper right corner of the fax machine)
2. Keep pressing the setup button until you get to the fourth option which says "Advanced Fax Setup"
3. Press OK to select the "Advanced Fax Setup" menu
4. Then using the left or right scroll arrows (below the OK button) scroll till you get to the sixth option which says "Fax Speed"
5. Press OK to select this menu item
6. Press the right scroll arrow till you get "slow" for the fax speed.
7. Press OK to accept this selection.
Then initiate a fax as you normally would.
hope this helps if you have further problem do let me know
Sep 23, 2008 | HP Officejet 4315 All-in-One Printer
Question
First, i suggest you try this. Remove batteries then press and hold power button for 15 seconds. Wait a further 1 minute then reinsert batteries and try again.
If no good, try this. If you can get to the MENU mode (in stored pics), scroll right to SETUP, press centre button to OK it. Scroll down to SETUP1. Scroll right, then down to initialize which will be lit yellow. Then scroll right and scroll up when ok will be lit yellow then press centre button to OK it. This will return camera to factory defaults including set up language.
Good luck !
Aug 29, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Password problem
Witch password is that?Admin password?Bios Password?Superior Password???
Let me know so u can get help!
Mar 13, 2008 | Lenovo 3000 C200 Notebook
Won't respond to remote
Access servicer menu,run initial set-up. Have you already tried hard re-set? Leave it unplugged from AC overnight==== Also,please verify model #
Oct 05, 2007 | Sony KV-36FS100 36" TV
Sony FD Trinitron WEGA KV-36FV300 36" TV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
