Question about Nokia 3110 Cellular Phone
I have a problem with nokia 3110c. i have setup the phone memory code before this long time a go and it is working before. however, now i have a problem, when i key in the code, is is not accepted by the phone.. is just stuck for 1-2 minutes, then blink again. so until now, i cant use my phone..if a need to reformat it, how i can get all the phone numbers befeore reformat? regards, amir
  • 44 Answers
Since you have changed your password, you got only 1 alternative: go to the required service centre and get your password refreshed..
Posted on Dec 11, 2009
I NEED RESTRICTION CODE FOR 3110C 354206/03/720307/7
RESTRICTION CODE FOR NOKIA 3110C 351939039190487
Aug 06, 2011 | Nokia 3110 Cellular Phone
My nokia 3110c is blinking n switch off after the logo appear
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step. It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime.
Apr 19, 2011 | Nokia 3110 Cellular Phone
How to format nokia 3110c phone
sir i think the phone memory of my 3110c is full.. so when i press the power button to turn it on.. it hang.. i cant even type th code.. any sulotion sir?
thanks
Apr 15, 2010 | Nokia 3110 Cellular Phone
My nokia 3110c not working properly
Clean and dry the battery terminals, check if the battery has swollen which indicates poor battery, reset all the settings to factory default, possibility of bad memory cells (memory card), it seems the handset is still in warranty period, contact nokia customer care for free repairs or replacement.
Oct 08, 2009 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
method
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
NOKIA 3110C DOES'NT WORK WITH MEMORY CARD
Dear sir,
I have Nokia 3110c mobile.When i was insert memory card(micro sd 1gp),it was continuously restarting.So please give some solution.
Jul 16, 2008 | Nokia 3110 Cellular Phone
Securty code for 3110c
how to format phone memory? plz i humbly request u to provide me code for formatting my mobile nokia 3110c
May 08, 2008 | Nokia 3110 Cellular Phone
Nokia 3110c mobile, i forgot security code.now how to reset security code?
Hi, I will be able to get you the master code to turn off the security code and reset to what it was when it was new (0000) it will remove the security code and won't ask for the code.
The code will only work if it is asking for the security code when you switch the phone on.
The code won't work if the wrong code has been entered more than 5 times, if it has the phone is hard locked and can only be unlocked using flashlead and unlocking software. Shops will not do this anymore as it is illegal!! You might be able to buy the software of the net.
If the phone is not hard locked i will be able to give you the master code that will reset the security code giving you access to your phone.
I will need your IMEI number, which is on the back of the phone under the battery and looks like 123456/12/123456/1 it is 15 digits long.
I will need this information as every phone has a different master code based on the IMEI number.
Let me know and i will be able to assist you further.
Apr 28, 2008 | Nokia 3110 Cellular Phone
Software
nokia 3110 classic software
Apr 03, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
89 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
