Question about Nokia 6300 Cellular Phone
Hi! My screen is white when turn on the phone. When I removed sim and memory card and turn on again, I see fabric black/gray background but can not see menu or any other commands.. Thanks in advance..
    President:
  • 1,884 Answers
It seems to be a corrupted firmware. Nokia allows you to update the firmware over the net. How???
Fully charge the battery, backup the data on the phone, Connect the phone to the PC through a USB cable only. Start Nokia PCSuite and allow a few seconds for the suite to connect to the phone. It will display on the suite that Nokia 6300 is connected. Click on update firmware and follow instructions. When suite finishes, your phone would be as good as new. Restore the data to the phone.
For more info read the following link.
Updating the Phone Firmware (Nokia)
Posted on Dec 11, 2009
Screen has gone white - if this needs to be sent off for repair my phone memory will be wiped - how can I transfer my pictures etc off without being able to read the screen?!!
try to remove the memory card of the phone... or, you my also synchronize your phone to your pc..
i just want to advice you that you can fix this problem by checking any updates for your phone or by doing a full reboot. to do a full reboot, just remove the battery and sim whilst the phone is on. then insert the battery without the sim, then turn it on. remove again the battery without turning it off. insert the sim and the battery. hopefully, this works chrisine.
Nov 28, 2010 | Cell Phones
Help please! My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the...
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
Mar 29, 2010 | Nokia 3230 Cellular Phone
My nokia 5800 has frozen on the nokia screen with white backgroun
The same thing was happening to my phone. I removed the battery, sim card, and memory card. I then replaced the battery an turned the phone on and it loaded to the main screen. I turned the phone back off and put back in the memory card and sim card and then it worked. Hope this helps.
Nov 18, 2009 | Nokia 5800 XpressMusic Smartphone
White screen with the hour glass wont go away
try to remove your sim card and the memory card out of your unit and try to open it again
If that work then have it run for 5 minutes then turn off again put your sim card not your memory card, then turn it On again
inform us what happen
Nov 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
The phone turns on then the screen goes white
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Regards,
Ayyasam
Jul 31, 2009 | Nokia 6500 Slide Cellular Phone
Nokia n70 blank screen or white screen
Your phone's real messed up.. Uhmm.. Listen, this may or may not work, but do try it before you do decide to go to a technician.
Hard format method:
  1. turn phone off
  2. hold the following keys WHILE its turning back on: (3 + * + green call key)
  3. do not let go until it asks you about your location
That hard formats all data on the phone, but your phone may need to be reprogrammed if the entire software is corrupted. Here in the philippines it costs 300 pesos, which is cheap. I dont know about the price from where you come from.
Anyways, negotiate (if possible) for a better price. It could also be a damaged hardware from within that may need fixing or replacement.
Let me know how it goes
johnny
Sep 03, 2008 | Nokia N70 Cellular Phone
Nokia N95 Wont start up properly
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Jan 29, 2008 | Nokia N95 Cellular Phone
K800i
So you mean to say your phone won't turn on at all? Have you tried removing the memory card, sim card and then the battery, put the sim card in and battery, turn it on without the memory card and see if it works...
Dec 10, 2007 | Sony Ericsson K800i Cellular Phone
Nokia 6288 wont turn on
If you encounter situation like below on your phone,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your phone! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
Nov 14, 2007 | Nokia 6288 Cellular Phone
Nokia 6300 Cellular Phone Logo
102 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
