Question about Microwave Ovens
The camera is not turning on. The lens is out when it should be inside when its turned off. It keeps beeping when i try to turn it on but it will not switch on.. constantly beeping.
  • 1,305 Answers
Sounds like you've got a lens error and the beeps are signaling your lens is stuck. With the camera laying on its back, try tapping the lens ring while pressing the start button. You may just luck out. It's about all you can do without taking your camera apart.
Posted on Dec 11, 2009
SOURCE:
Hi, I have Sharp SPC 182 clock, which is not turning on..just a flickering display with beep keeps coming when plugged in..
If the display is flickering I would consider it being a bad main circuit board. If it just keeps beeping when power applied could be a bad touch pad too. Unplagging the pad and reapplying power and see if it beeps with the pad unplugged that would tell you if is the board. If it still beeps with the pad unplugged it is a bad board. It may be thinking your standing there pushing a pad. Either get both or replace the unit. Prices have come down drastically. Encompass parts was selling parts for those, sorry I do not currently have their number.
Jul 02, 2018 | Sharp Microwave Ovens
Panasonic convection nn-cd9975 turntable turns sometimes and not other times.
Most likely a broken turntable drive coupling or a sluggish motor. The coupling has a D shaped hole inside to keep it from Slipping on the shaft, so Try to turn the coupling by hand, if you feel it slip or it is very easy to turn, it is probably a broken coupling.
May 25, 2017 | Panasonic Microwave Ovens
The oven door locked on my GE JKP64 after self cleaning and keeps beeping locked door every minute
Turn off the house breaker for five minutes and then turn back on, if you have the same problem you will most likely need a repair man.
Apr 06, 2014 | GE Microwave Ovens
My Micro will not heat and it keeps beeping I can not get it to stop...
Its likely beeping as it is not heating, I presume light goes out when door closed and a turntable turns or not?
I can provide possible reasons for no heating etc.
Dec 21, 2012 | GE JES1142SF Microwave Oven
F5 keeps blinking and stove is beeping
hello,
This f 5 code indicate or means that the oven has detected a condition it needsto check.what u need to do to solve this problem is to apply the below step as a guild.
Press "Cancel" to clear the display and to stop the beeping sound,then try turning the oven off and on again. If you still see the "F," turn offthe power to your oven and wait five minutes before turning it on again. If youhear the beep or see the "F" when you try to bake or broil again,
If your oven still has the warranty this will be covered under this ok
Hope this is very helpful for .
Thanks for using fixya.
Jul 27, 2011 | Microwave Ovens
How do you turn the beep off?
Finally worked out how to do this today! I don't know what model you've got (I don't know what one I've got - it's built in and we've lost the manual) but try pressing the START button for six seconds. This should change the default from 30 beeps to 3 beeps. Bliss.
Apr 16, 2009 | Neff H5470N0GB Microwave Oven
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
