Question about Funai F3813D 13 in. Combo
Funai tv 2000 mk7
Hello, please tell me why amplifier pnp 2sb698 it,s broken everytime I replaced. Thank you!
2 Suggested Answers
  • 42927 Answers
SOURCE: HELLO!GIVE ME PLEASE FUNAI TV REMOTE CHUNGHOP RM-366C REMOTE CODES.
Your Funai remote may not be programmable to control other devices. If it is programmable, you can se its code search function to find a code that will control your Chunghop device. You may have to use another programmable remote to control your Chunghop device separately.
Posted on Jan 10, 2015
How much money will it cost to fix my tv funai
Broken screen!! No repair. Replacement only can be done. Will cost around 2/3rd of the total cost of a new TV. Will be wiser to buy a new one. http://electronicshelponline.blogspot.com/
Apr 17, 2016 | Funai Televison & Video
DVD/VIDEO
visit this site for owner's manual
http://tv.manualsonline.com/manuals/mfg/funai/ewd2203.html
Aug 21, 2008 | Funai Emerson DVD/VCR EWD2004
Jan 10, 2015 | Funai Televison & Video
Tv was dead no vvidei no sound after checking found that power supply capacitor and horizontal deflection output transistor was defective i lost that tr no part no please tell me what should i do?
Hello
There are few models of Sony telivisions which uses transistors in vertical output section. It will be a matched pair of PNP and NPN transistors. According to Sony schematic which I have with me used 2SB6494(PNP) AND 2SD669A(NPN) as vertical outputs and 2SC2383 as vertical drive, 2SC1364 as vertical oscillator. Just try to get the orginal numbers or find its equivalents from data book. Ok.
Oct 17, 2010 | Sony KV-35S42 35" TV
Broken remote How do i switch between Aloge and digital Channles
I called FUNAI CORPORATION
Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
I was told the only way to get it back to digital was to order a replacement remote. They told me there is no universal remote that will put the tv back to digital. If you want to order a new remote call the number above and choose option 4.
Aug 20, 2009 | iLO IWT3206 TV
2000 W reg ford escort wheel nut torque settings
2.0L DOHC Engine 85-105 Ft Lbs EX 2.0L DOHC Engine 65-87 Ft Lbs
Please let me know if this information is helpful. Positive feedback is appreciated. Thank You!
Mar 28, 2009 | 1989 Ford Escort
What is the remote model number for a Symphonic tv/vcr model #SC309C? Also for a tv/vcr SC3909 and tv/vcr TVCR9G1 ? I'm trying to figure out if I have the correct remotes for these tv's. Thank you
Funai manufatures all Symphonic products:
Remote for SC309C = Funai Part Number: N0150UD
Remote for SC3909 = Funai Part Number: N0258UD
Remote for TVCR9G1 = Funai Part Number: N0200UD
Hope this helps!
Triron72
Mar 26, 2009 | Televison & Video
Hello, I have a rainbow picture on the top of my rear projection JVC TV...model #jvc av48wp30. Can you please tell me what that could be?
Hello buttermouth,
I gave this advice out before and it applies in this case so here goes:
What is happening is that your convergence amplifier modules are beginning to go bad. These amplifiers are what amplify the signals used for convergence (how the RGB lights line up on each other) when they go bad the RGB lights tend to bow towards the center of the TV and the colors begin to mis-align. There are many sites devoted to doing the changing of the amplifiers yourself,however although these sites are accurate and give the instructions on how to change the amplifiers they do very little for actual troubleshooting and finding the underlying cause of the problem. In most cases its just that the amp modules have gone bad, but sometimes there is an overheating problem that triggers the damage. I would suggest having a TV repair person come to your place to check the problem and to fix it. The repair should cost about $250.00 - $500.00 depending on the shop and the components used.
I hope this helps
Thank you,
Shuttle83
Jul 17, 2008 | Televison & Video
No sound from a Philips model 60P8341...
Hello Jarvis1,
This is an indication that the actual sound output is working, but the amplifiers to the speakers are not. How you could take care of this is to check in there are any loose connections to the speakers. Then check if you have sound coming from the leads of the output stereo amplifier (You will need the schematic and an audio tracer/tracker to find this location and test for sound). I would venture that there would be no sound from the amplifier. If not you will have to replace the amplifier chip. I would suggest getting a qualified TV technician to perform this task. If you do have sound at the output of the strereo amplifier chip, then it might be a case of the earphone jack switch being broken, let me explain when you plug in your earphone the speakers are disconnected by a switch in the earphone jack if this switch is broken it could disable the speakers and produce these results. There is also the possibility that you have the speaks disabled from the menu of your TV (check this too, actually check this first).
I hope this helps,
Thank you,
Shuttle83
Jul 03, 2008 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
215 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
