Question about HTC P3300 Smartphone
The front panel is giving away and opening up. The phone works fine but there is a gap showing up. The gap is at the bottom left corner if you hold the phone. What to do?
    Sniper:
  • 143 Answers
Ebay.
iv just got one, i had the same problem but now it looks like brand new.
the only problem leaving it is that it will get caught an snap like mine did. my new cover cost 7.50 inc p&p and took a week to come, it includes a screwdriver but no instructions however it is pretty straight forward to install.
the HTC p3300 and the XDA orbit is the EXACT same phone under the shell..
Posted on Jan 07, 2010
How do I open the front of a Meile W911 Front loader
remove soap draw, remove screws on left hand side(T20), open drum door, three 10mm bolts around drum, open filter flap and unhook black hose from flap if there is one, the bottom left hand corner sits on top of a metal clip to hold it in position just pull to remove,
Sep 18, 2014 | Washing Machines
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
How do you open up a Sony rm-gd008 remote for cleaning?
  1. Maybe worth a shot, carefully thou
  2. Remove 2 * screws under battery cover
  3. front of remote: slide down the bottom cover (where rec, pause, etc option is)
  4. push both egdes of the slide area outwards, to totally remove this slide cover
  5. further more, now push both the above slide edges even more .. till bottom of (front face) cover loosens up. Whilst lifting this only a little at a time ...
  6. Gently remove /loosens only lower ends (only at this stage) of the 2 silver edge stripes... by .. lifting up (away from face of remote) ..whilst .. moving them outwards. ** i.e up, then outwards) Do not remove top edge of silver tip yet
  7. start separating left n right egdes with sharp flat point from under silver side strip, " digging" downwards towards bottom of remote
  8. At this point, the top edge of remote may be separated, but not necessary.. if you can pull insides out from bottom, PREFFERED OR .. can be done by:
  9. using flat edge - loosen/pry 1cm from corner on top tip of edge left n right digging downwards n outwards towards bottom of remote .. enough gap to use a little pressure if you must
  10. then if feasible, separate remote face .. also 1cm from right n left corner alongst each side from top corner
  11. .. now can remove silver side strip completey.
  12. Hope this helps, cheers
Dec 04, 2012 | Televison & Video
How do I get to the belt to replace it? Crosley CDG6000W dryer Rev 10 Serial # 10178386WH
You have to turn the drier upside down and work thru the bottom.
Sep 15, 2011 | Dryers
My washer isnt draining isnt draining all the way and the drum isnt spinning at all but i can hear the motor running! The belt is not broken!!
Hi, Margo, with the limited info provided..you could have several different problems... giving you approximately the same results that you are seeing but I will that would give you a quick checkout procedure for a very common problem and it may solve your problem.
(1) Unplug your machine from the wall power (120VAC). Remove the front...bottom panel only. This panel is the bottom 1/3 of the machine's overall front panel. There are several screws maybe 4 or 5 that will have to be removed. There are 2 screws, 1 screw on the top left corner of the bottom panel and 1 screw on the top right corner of the bottom panel. The other screws are located at the extreme bottom left corner and and extreme right corner. There may be 1 screw in the middle on the bottom panel at the floor level. These screws are probably 9/32" hex heads screws with a phillips head also . You probably will have to tilt the machine slightly backward.... lifting the front legs about 2 inches off of the floor in order to gain access to the bottom screws. You may want to have a friend to help as the machine will probably have to be pulled away from the wall in order to tilt it backward. Warning: this machine is extremely heavy.... so proceed with caution. After you remove the bottom panel... you can set the machine back down on its front legs.
(2) Have some dirty towels available to mop up any water. At this time look into the bottom of the machine in the front bottom middle area ...you should see a round black assembly that has a removable cap that is about the size of the gasoline cap on your car. Turn this cap Counter clock wise (CCW) and remove it. Inside the housing you may see derbish (pins, screws, strings, buttons, hair etc) blocking this 'button trap.' Clean all the trash out of this housing and reinstall the removable cap tightening it in a clock wise direction. Mop up any water. Reinstall the bottom panel. and reapply power (120VAC) to the machine and attempt to run a cycle. Hope this helps you to solve your problem. Handy Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Apr 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Freezer drawer closes on right but gaps on left side for Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator, frosting contents. No contents blocking. Can manually hold left side closed, but wont...
I had this problem with my Kenmore bottom freezer drawer also. I found that the problem was I had too much weight at the very front of the drawer. Try reorganizing and moving items, especially heavier items away from the very front. Worked for me.
Jul 10, 2009 | Kenmore 73503 Stainless Steel Bottom...
How to open this box for gateway e-2000
The front cover for that Gateway in my picture is hinged at the top front corners; the inside surface of it is showing face-up (black) on the top of the case. Flip it upward, around and down to cover the front panel; on the top of the left side cover there's a press-in latch button (kinda rectangular, in the recess that the front cover was hiding). Push that latch button in (toward the outside surface of the side panel) then pull the top of the panel outward and down, away from the case as if the panel was hinged at the bottom. Once the panel's at a 45º angle, you can lift it up and away from the case.
Your case is similar, I'm sure. Look for a semi-hidden latch button hiding in the recesses.
also check ou this link
click here
plz rate this post as good as u can, so we can help others.
Jan 30, 2009 | Gateway E-2000 Deluxe PC Desktop
Cannot get front panel off kitchen aid dryer to reach heating element model # KGYS850JQ1
Remove the front panel by following these steps:
1. UNPLUG dryer before servicing.
2. Open lint screen and remove lint screen filter.
3. Remove the two screws at the lint screen opening.
4. The top panel with console, should lift up at this point (you may have to pull it towards you slightly if there are retaining clips holding it in place).
5. Unplug the door latch plug (small white connector plug).
6. Locate the retaining screws that hold the front panel in place. There should be one screw on each side of the cabinet interior at the upper left and right corners of the front panel.
7. With the screws and connector plugs removed, the front panel should lift up slightly, then come off.
NOTE: Note the position of the small retaining clips at the bottom left and right corners behind the front panel. These clips will insert into two slots at the bottom corners of the front panel to hold it in place when re-installing.
I hope you find this information helpful. If you still have questions, please let me know.
PS You can go to searspartdirect.com and type in the same model number you provided. There are helpful exploded view parts diagrams that can assist you. The "Top and Console" and "Cabinet" headings will help you with disassembly (if needed).
Sep 04, 2008 | Dryers
HTC P3300 Smartphone Logo
47 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
