Question about Sony KV-32FS13 TV
I can't get the video menu on the tv, even though the programmes such as BBC are coming through the video recorder - the remote is RM826 - loads of buttons, found the 'hidden' ones which tuned the programmes in, but can't work out which ones to use to tune a station to the video itself - unfortunately I don't have a user manual. Can you help? Thanks
  • 3,230 Answers
Well first of all you can download user manual from the below link -
http://www.devicemanuals.com/guide/Television/Sony/Sony-TV-KV32FS13-User-Guide-TXpVd016Zz.html
and then try according to the manual says.......
Try this also - Turn off your TV for 4+ hours and then turn it on again and check. (note. turn off the TV from the main housing). It helps you to reset your TV to default settings.
Good Luck!!
Thanks
Posted on Dec 11, 2009
SOURCE:
Issues with iPlayer and any BBC programmes not loading on jvc smart tv (BBC has the tv on its list as should be working
Check if there is a software update for the TV. That might resolve the problem if JVC knew there was a problem between their TVs and the BBC iplayer. Otherwise contact JVC to see if their is an issue which has not been sorted out yet.
Jul 07, 2018 | JVC Televison & Video
Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
Oct 16, 2007 | Televison & Video
Playback of Topup TV Sky / ESPN Recordings
I am just guessing but you may have an ant-copy signal embedded into program signal causing to when you are trying to look at a recording to another source. If that is the case then there is one way that would work. You need to connect inline with the video line out to the in of the other unit (yellow) and that would solve the problem. Go to xdimax.com and check out a dimax signal adaptor( can not recall what it goes by,description-wise) This is almost like trying to use a hdmi output and a audio/video connection at the same time.This also happened when doing the same with some video decks (vcr)
Sep 02, 2017 | Thomson Televison & Video
I have just bought a new LG 42LM620T TV. The picture is fine but every so often the sound is a little distorted. It's as though the sound has been recorded at too high a level for the speakers. It
No doubt in the audio menu for your TV there are several tweaks available in there - maybe even a graphic equalizer and perhaps other potential modifications. Access the audio menu with your remote and play around in there. You may be able to soften the audio up a bit. Good luck.
Jul 26, 2017 | Televison & Video
Unable to record any BBC channels on tvonics dvr
I had this problem and did 'Menu' then 'Settings' and 'Reset set top box'. This will lose your channels and timers, but the recorded programs will still be there. After I did this I could record again on BBC!
Jan 07, 2010 | Televison & Video
I WANT TO RECORD A RADIO PROGRAMME BY DOWNLOADING
Are you in the UK?
1 The easiest thing to do is to record it using a freeview box onto either a video or other recorder.
2 If that's not possible try listen again if on bbc.
3 It's difficult to record directly onto a pc without a tv capture card (and essentially doing 1 above) when you can set a timer to do it automatically.
4 if you don't have that you can connect the headphone output to the microphone input and use the Windows Sound Recorder to then recod the outpu
Nov 08, 2009 | Packard Bell Easy One Silver 2120 Notebook
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony KV-32FS13 TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
