Question about Motorola Mobility C115 Cellular Phone
Opening the case to repair charger connection
I have a bad connection behind the charger socket on the phone. How am I able to split the casing to get at this connection?
    Sergeant:
    Champion:
  • 221 Answers
Don't try this at home...Take it to an authorized Service Center.
Sahaja Yoga is the Mahaa Yoga and is the Only Solution to all the Problems of World. This is FREE OF CHARGE.
Posted on Mar 31, 2008
IPhone 5 was working perfectly, but when I plugged it in to charge, it didn't start charging. I could still use the phone. Now the phone died and nothing happens. Is the battery dead (as in broken)?
I would guess that you battery is fine, it is either your charger is not working or worse case your charger socket on you phone is damaged. Try connecting your iphone to your computer via the USB port and charging cable, if your phone starts to charge you know you have a problem with the plug side of your charging cable which is where your transformer is. Be aware that if your battery is totally flat it could take several minutes before you hear the beep from your phone to indicate that it is charging. If that doesn't work it could be your charging lead that is damaged so try charging with a different lead. If still no joy then you could be in trouble as the charging socket is soldered to the mother board and could be an expensive repair so fingers crossed it is only the charger that is damaged.
Jan 02, 2014 | Apple iPhone Smartphone
I have a replacement blade holder for model number 320.28223, but am unable to figure how to split the case in order to make the repair.
Often screws are hidden behind rubber mouldings on the outside of the case, try to prise up any rubber knobs or panels to see if screws are behind them.
Nov 30, 2013 | Sears Saws
Charger not staying put
Sounds like the socket is faulty, probably broken the supports inside the case. Only way to fix it is to take it apart and either repair the socket or fit a new one. It could be quite expensive depending on how much of the laptop needs taking apart. I repair them quite often but am in the UK people pay anything from 60 dollars to 150
Feb 04, 2012 | Compaq Presario CQ60-220US PC Laptop
Bad screen flicker in certain positions on my travel mate 5330 screen, can I cure or do I replace?
I understood your problem....sometimes it cause due to if your laptop running on direct charger i mean without battery....best solution is use power regulator.....
Or if further problem occurs then you should replace your screen by opening the back case and follow steps...
1 ) open motherboard cabinet here you will find socket which contains you screen's pin disconnect it from that socket.
2 )then replace your screen...
3 ) refit back case
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 22, 2011 | Acer Computers & Internet
The pin that u put the charger in has went back in the laptop. how to open it to get to it to fix it.
The power socket on a laptop is usually soldered directly to the mainboard. Sometimes the socket is on a seperate smaller daughterboard or on a cable that connects to the mainboard, but usually this is not the case. Opening the laptop to perform this repair can be very trick and time consuming. I would certainly not recommend an amateur attempting this repair as usually the entire board needs to be removed, the socket de-soldered and a new socket soldered in place. Not for the faint hearted! If you wish to provide laptop model details I may be able to provide the screw locations etc and disassembly guide.
May 29, 2011 | Computers & Internet
My battery cord has split right wher it goes into the charger how should i fix this
The best way to fix this is to open the case, strip both wires back to expose the wire, slide a shrink wrap insulator over each individual wire, and then solder the wires back together. When connected, slide the shrink insulation down over the solder connection and then use heat to shrink the insulation around your repair, then close the case back up.
Feb 09, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
My samsung j750 suddenly went dead after restarting power. the power button does not work at all. but after connecting the charger, the lcd displayed power is charging but still cannot power on. any ideas?...
Hello, I'll list the possible cause(s) below:
  1. Since its a flip phone, there is every possibility that the flex that connects the power button to the Phone board is weak as a result of frequent opening and closing of the slide.
  2. It is also possible that the power button is not contacting the phone board well or the key pad is bad
  3. The software of your phone might also be corrupt and maybe that's why its not powering. In this case you need to take it to samsung shop or any phone repair shop so that it can be reinstalled.
  4. The battery might be bad.
Observe or check your phone very well and see if any of the above might be the problem.
Best wishes.
Nov 20, 2009 | Samsung SGH-J750 Cell Phone
Behind the crankshaft pulley the casing is cracked(split) leaking
Replace the cover behind pulley which requires removal of all accessories in the way,alternator,tensioner pulley,waterpump,and others.Belts,and possibly removing the motor.
Apr 09, 2009 | 1996 Plymouth Neon
Charge Socket
Bought a faulty F20 off EBAY with a broken USB socket.
It seems like a common failure mode.
The one I had had sheared directly of the internal board and their was no PCB track left for re soldering.
I eventually managed to repair the unit by buying a new socket and attaching fine wires which were hard wired to other parts of the PCB then using epoxy glue to refasten the socket. I would consider it a difficult and advanced repair. (Its like micro PCB surgery)
Opening the case is relatively easy. Remove the screws and then use something like a blunt table knife to gently slide between the two case halves until they part bit by bit.
Hope this is of some help.
Apr 18, 2008 | Navman F20 GPS Receiver
Motorola Mobility C115 Cellular Phone Logo
87 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
