Question about Linksys Wireless-G WRT54G Router
Connected but could not access internet
I had reset my router to default and then connected to it using my laptop. I am able tp ping the router and also it connects fine and shows full signal strength , but I cannot access any websites.
If I use a wired connection with same ISP , everything works fine.
    Problem Solver:
  • 14 Answers
When connected via wireless open a command box and type "ipconfig /all" and note the DNS settings assigned to your laptop. Then do the same with the wired connection. If the wireless connections are not receiving valid DNS settings, that would explain why you won't be able to access any Web sites. You can then re-configure your router to issue the correct DNS settings as per those issued to the wired connection. You could alternatively add these DNS servers as static settings on your laptop, but its best to do it on the router and leave your laptop set to automatic.
Posted on Dec 11, 2009
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
My laptop will not connect to our wireless router at work. It says connected, but no internet access.
The laptop might be connected to your wireless router but is unable to connect to the internet
check if you can ping websites
- click on start > Run > type in "cmd" > in the command prompt type in "ping www.yahoo.com"
- if you get 4 replies the problem might be with your browser.
- if Ping fails try typing "ping 209.191.122.70" which is the IP address for www.yahoo.com
- if ping is successful then the issue is with your DNS server. contact your ISP to get alternate DNS
- if Ping fails try pinging the default gateway or modem IP (you can find the default gateway by typing IPCONFIG)
- if ping is successful then there is a problem with your internet provider
Also you should try disabling your firewall and runnning a virus/malware scan
Mar 30, 2011 | Computers & Internet
Hi, my Toshiba NB 200 won't connect to the internet, says reset router, server says router is fine and I have reset it but still won't connect. Running Windows 7
Try disabling Firewall and check the status. If it solves the problem then configure Allow Incomping and Outgoing option for the Router.
If Not, please provide me the following details:
1> Router Make.
2> Are you able to ping to the routers default IP?
3> Do you have Admin access in the system?
4> What happens when you use any other form of Internet. EX: Ethernet, Modem
5> Do you notice any yellow exclamatory Marks in Windows device manager list for Network adapters?
Nov 30, 2010 | Toshiba Computers & Internet
I change The IP to 192.168.1.102. and if I connect
after reset the wireless device you can connect only through 192.168.1.1 or 192.168.0.1 IP address.
Mar 02, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Jan 31, 2010 | Computers & Internet
I have a Linksys Wireless G WRT54G Router version 5 and I lost my setup disk and cannot access the internal web based setup and Iv done everything Iv read to do and now its not even showing up as a...
Hi there. No need to run the setup CD. Check the IP address first to see if the computer is communicating with the router. Go to command prompt (if XP, simply click start then go to run and type in CMD and hit ok. A black screen will pop up. Type in IPCONFIG then enter. Check the IP address and default gateway (by default, the router's IP is 192.168.1.1 which will show as the default gateway). Launch internet explorer and type in the default gateway on the address bar. (No www). If you cant pull out the page. Go back to the black screen (START>RUN>CMD) and type in ping (default gateway) ex. ping 192.168.1.1 there is a space between ping and the default gateway. If you got 4 replies you should be able to access the router's page if not, reset the router by pressing and holding the reset button of the router (usually it is the red hole at the back of the router along with the ethernet ports) for 30 seconds. After 30 sec, power off the router (unplug at the back)never release the reset button and wait another 30 sec then plug the power back in and wait another 30 sec before releasing the reset button. You should be able to access the page then. Go back to the black screen (START>RUN>CMD) then do again a ping test. type in again ping and then the default gateway. (ex. ping 192.168.1.1). You should be able to access the setup page now.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
I have a toshiba laptop, already have existing computer all set up but having trouple conncted laptop to wireless. Have adsl modem and tp link router. tp link is asking or network key to be able to...
Your wireless network is secured and thats why its asking for the network key. If you dont remember the same, contact your router manufacturer or ISP and get the router reconfigured
Jul 03, 2009 | Computers & Internet
WPA encription disappeared, cannot access router
First get the DNS setting of your ISP. If you have activated the internet connection icon on system tray. View its status then i think it support menu. It will give you the details and the ISP DNS. Or ask your ISP provider.
Then connect your Computer LAN to LAN1port of the router thru LAN cable. Set your Computer LAN setting, input your LAN ipadress say 192.168.1.2 then subnet say 255.255.255.0 then default gateway ot the router say it is 192.168.1.1 then in DNS input your ISP DNS. Test it goto router's utility page, input user and pass. Or ping the router, on windows dos type ping 192.168.1.1 enter, you will got 4 lines for good connection.
Now connect the Internet cable to WAN port if it is LAN cable. browse the internet. This is the first step.
May 24, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot "ping" 192.168.1.1 (default gateway)
1) yes, referring to the router's IP address.
2) I determined the IP addresses of all my computers and tried to "ping" them but could not "ping" any of them. I can "ping" the IP address of the computer I am working from but I don't think that helps in TS this situation.
3) I'm wondering if my router is fully set up correctly. Do each of the computers have to be "saved" in the router's settings?
Jan 11, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Laptops not able to connect
Hi, Run a command window (Start, Run, type "cmd" without the quotes, Type "ping 192.168.0.1, it should answer back> Reply from 192.....TTL=xx, if yes, then you are connected to the router; If no, type "ipconfig /all" to check your IP settings which should match your router's DHCP assigned numbers, others you can try are /flushdns, /release, /renew/ Type "ping 209.131.36.158, it should answer back> Reply from 209.....TTL=xx, if yes then you are connected to the router and have access to internet; If no, and yes to 192..., your router is not granting you internet access or the router itself does not have internet access. Review what corrective measure/steps you have taken earlier that could have affected your internet access. Make sure that your Default Gateway is the IP add of your router. Post back should you need additional information. Good luck and kind regards.
Aug 26, 2007 | Actiontec GT704WG Wireless Router...
Linksys Wireless-G WRT54G Router Logo
132 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
