Question about RCA DRC8335
DRC8335 THE READOUT SAYS HELLO ( SCROLLS ACROSS). CANNOT TURN IT OFF OR DO ANYTHING i HAVE TRIED THE CONTROLS ON THE SET AND THE REMOTE. NOTHING WORKS. i HAVE UNPLUGGED IT FOR 24 HOURS TO SEE IF THAT HELPS. jUST PLUGGED IT BACK IN. NO CHANGE. STILL HELLO AND NO CONTROL..
  • Richared Young Dec 11, 2009
    WHAT ARE THE ALTERNATIVES
  • 15,935 Answers
CLICK HERE for your manual.
This is a very common and known problem with this particular unit.
The frozen "HELLO" message indicates that the RCA unit has failed to finish its boot up diagnostic sequence. This could be brought about by a failed component (most likely) or a glitch in the firmware (least likely). This would be so if there is no lock symbol likewise displayed.
To try and address a possible firmware glitch, unplug the unit from the wall outlet (if haven't been tried) and allow unpowered / disconnected condition for an extended period of time (say an hour or so).
Should the above be not corrective, options then are:
  • consider a DIY (do-it-yourself) repair if and only if very familiar with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe working practices. Access to a Service Manual or at the very least, a schematic diagram would be an advantage (which is a challenge in itself);
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to seek the services of an authorized RCA Service Center (specially if still under warranty) or a qualified professional.
If you are considering a DIY, initial checks would be for the presence / absence of the different systems voltages in the power supply section with particular attention to the filter capacitors.
The problem is a bad electrolytic capacitor on in the power supply board. The cap is a 470uf 16v (number C226 on the power supply board). Replace it with a 470uf with a rating of 25v to 50v and it should restore the power fucntion to normal. I have fixed six units this way so far.
oR IF YOU'RE NOT TECHNICALLY INCLINED... Call this number. 1 877 805 0519 This is Customer service. This IS a known problem with this unit. They may send a return label to send the player back. The company should take care of it.
Hope this helps you.
Thanks for using FixYA
Posted on Dec 11, 2009
  • 2,237 Answers
You could try resetting it to factory default (while it's off, hold the power button for 10 seconds and release). if "hello" stays on there, the processor is bad. unfotunately, it's a common problem with the rca. if you figure out how to fix it, let me know. i've seen many of these with the same problem and rca says to replace it. figures.
When my tv is powered on, it displays the device menu and continues scrolling through it, but will do NOTHING else. I've tried to reset, and nothing. The tv will not respond to the remote at all.
A suggestion here: If possible to remove front speaker grill and inspection plate that should be behind it---locate the bundle of wires that comes down from front keyboard with the buttons and follow it to the right and down---should be one or two plugs in-line--------disconnect them with the set off and power set back up with remote.
If the problem is gone you have a bad micro-switch on the front of the set------buttons on the keyboard there have priority over the remote---hence you cannot if the problem is there stop it with the remote or do anything for that matter.
Let me know what happens and I will suggest options.
May 31, 2012 | Televison & Video
I accidentally pressed a wrong button when I was changing back to TV after watching a video. then the screen became snowy and I'm unable to get back to TV mode. I need help!
Hello rgas,
do you know if you have cable or satellite? Look on your remote and for a button called input or source and click on it. Remember what input it is set on first then try changing through each input. See if you get anything. If nothing still, go back to the original input it was on and change the channel to channel 3. If you have cable or satellite, turn it on. If nothing appears, go to input/source scroll through each input and hopefully you should get a picture. Good luck.
-Joe
Aug 30, 2011 | Televison & Video
RCA DRC8335 remote not working and dvd/vhs only scrolls hello how to fix and what is code for remote
That is the same problem I had with mine. The problem is not with the remote, but one (or two) of the capacitors on the power supply board. If you can solder you can replace them yourself for a few bucks. You can tell which ones they are by looking at the tops of them and they will be bulged out slightly. The fixes I found mentioned one specific capacitor, but I found a 2nd one that was bad as well. I replaced those and it worked fine, although it will freeze from time to time after constant use, I haven't gotten to diagnosing that problem. I just have been plugging and plugging it back in.
Sep 26, 2010 | RCA DRC8335
Recorder will not do anything only hello hello. I have unplugged for 10 seconds or more and still nothing happens
recorder will not do anything only hello hello. I have unplugged for 10 seconds or more and still nothing happens
Nov 16, 2009 | RCA DRC8335
LG RH266 DVD/HDD RECORDER The HELLO message keeps repeating when turning the unit on. So cannot receive picture etc Is there a code from the remote to fix this or a part replacement ?
hi,i have an lg 389h dvd recorder,it just says hello scrolling across the display,and doesnt respond to any functions on the,remote control,any ideas,cheers.
Oct 14, 2009 | LG DR787T DVD Recorder
DRC8335 DVD Recorder manual
http://www.retrevo.com/support/RCA-DRC8335-DVD-Players-manual/id/2771dj585/t/2/
Sep 11, 2009 | RCA Universal Remote Control
When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Jun 02, 2009 | RCA DRC8335
RCA DRC8335: shows "padlock" symbol
Mark. Use the emergency factory-set master password 9688 to cancel and remove any previously owner set parental control password. Refer to page 26 of the User Manual if needed.
RCA DRC8335 User Manual (PDF 1.92mb) <---click here to begin immediate download
Please rename the ugly unreadable (encrypted filename) back to the original as highlighted above in blue, once the download has completed. mikeadams110@yahoo
Aug 15, 2008 | RCA DRC8335
Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Jan 02, 2008 | RCA DRC8335
Red "not available" message on screen
The reason the TV doesn't respond to the remote is that the set is busy trying to change channels (or scroll through menu options.) because one of the channel-- up/down "button" is stuck on the front panel of the TV. They are very delicate, and respond to the slightest input. (You should see the CH light on the front of the set.)
So, I had the same problem, and just finished following the advice for fixing this problem by using a hair dryer and pen knife to remove the strip covering the "buttons."
I have to admit that I was afraid of what damage I might do in removing the little strip from the face of the TV, but I only paid $114 for the set at Salvation Army, and it's otherwise a great set, so I had little to lose.
Trust me, you can't hurt anything by removing the little panel. Just take your time, and let the heat do the work, lest you crease the strip. (It took about five minutes for me to get it off.)
I chose to disable the front-panel controls altogether by simply removing the little pads that activate the switches.
The pads look like tiny little rubber bands, about 3/8" across, and will stick to the double-sided adhesive when you remove the strip. (Don't worry, they are not attached to the set, and you won't be destroying anything in this process.)
I suppose you could always get replacement rubber thingies, but I'd just as soon use the remote, and avoid future hassles.
Aug 09, 2007 | Samsung TXN3071WHF 30" TV
RCA DRC8335 Logo
96 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
