Question about Refrigerators
The fridge freezer i have is a upright samsung RL36 S BSW, the problem we have is the freezer is working as it is supposed to, all power is working but the fridge has gone warm i would apreciate a solution to our problem asap as my wife is pregnant. thanks
  • witorr69 Dec 06, 2008
    hello : this is my problem #1 fridge is to hot is coold inside but the fan is no good is not working. is that normal thin with a brand new fridge?
  • davallou Jan 13, 2009
    I have this problem of freezer frosting and staying at -10f and shutting the fan to the fridge and therefore making the fridge section staying at 47f.
     it has happened every time I have company for the past 3 month it resolves by shutting the fridge and defrosting it completely what should i do to resolve it for good? should I set the freezer at 5f instead of 0f in winter would that help???
  • 833 Answers
Both of the other messages have it partly right. First, defrost the box completely. If you have access to the coils, use a hair dryer...but be careful of water/electricity as they don't mix well. If not, you'll have to turn it off and leave the doors open for at least one day to melt the ice inside. Dry what you can. Restart the box. Often, problems like this are a result of too many uncovered liquids, box set too cold, too much 'window shopping' or bad/dirty door gaskets. If the problem comes back, it will either be the defrost timer or low gas.
Posted on Jan 22, 2008
  • 770 Answers
First off yoyu need to verify the fan is running in the freezer
Posted on Jan 21, 2008
It's possible that the defrost system is not working properly and that the defrost thermostat is open or the defrost element is open. If these two parts test good then look for a defective timer or a stalled evaporator fan motor.
6ya staff
SOURCE:
Samsung Cool n Cool upright fridge freezer bleeping constantly, both fridge and freezer working OK
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Samsung Refrigerators
The top section, fridge, is freezing up, we only had it 3 days
Read somewhere that refrigerators are not supposed to be transported on their sides - that they are supposed to be moved in an upright position and that if you have transported it like that you are supposed to let it stand upright for about 8 hours before using it.
Mar 17, 2015 | Electra GENUINE Refrigerator Fridge...
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
There is no power fridge will not run
Put more coins in the electric meter! lol
Check socket with working desk lamp
Check fuse in freezer plug
Apr 02, 2014 | Woods Upright Freezer MU07W
I have a samsung fridge freezer upright i cannot get the lights on the top to stop flashing and there is a spasmodict motor sound keeps striking up and every thing in the fridge at the top will freeze ?
hi it will probally be the lower damper motor .. guy on you tube will be able to help , his email address is under some of the videos .. email him ..
Jan 31, 2011 | Samsung Freezers
Fridge compartment is freezing in my Hoover upright fridge-freezer. Any advice greatfully recieved. Thanks, Owen
have you tried turning down the temperature for the freezer or fridge? The fridge gets its cold power from the freezer, it is siphoned into it. So turning down the freezer temp may help but a sensor may have gone bad in the motherboard of your freezer and not closing off the vent into your fridge
Dec 06, 2008 | Hoover HCA390FFK Bottom Freezer...
Not Freezing/Cooling - A Red Glow...
  • the defrost timer and bimetal thermostat have apparently both malfunctioned. (rare)
  • if someone has worked on it in the past they may have bypassed the  bimetal thermostat.
  •  the bimetal thermostat turns off the heater if it gets too hot (above 45 in the freezer)
  • and the defrost timer is only supposed to stay in defrost for 8 minutes or so.
  • so considering the heater was on and it was hot in the freezer is evidence of these two components not doing their job.
Jul 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
188 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
