Hello Melissa !
What you need to do is to physically connect the printer to the modem, now your computer should be connected hardwired or wireless to this modem.
When you connect the printer to the modem , the modem will assign an IP Address to the printer, you can look on this ip address by printing a configuration report from the printer itself.
Now we have 2 options here, use the software that came with the printer (installation disc) to install the device and at some point of the installation it should detect the printer automaticaly, just remember choosing "network install"
If you already have the software on your computer, you will need to uninstall / reinstall the software so the computer can detect the new ip address. Or you can set the ip address manually by going under printer and faxes on the control panel, make a right click on the P4350 icon, go to properties, then the "Ports" Tab and click Add Port, you will need to select Standard TCP/IP, click new .. and then type the IP Address
This should connect your printer with your new modem - computer
Good Luck !!
You can contact me at:
[email protected]
