Question about Sony DHR-1000 DVHS VCR
The machine is connected to the power, but it will not work
I haven't used the machine for a long time. Powering the machine gives no result. The fuse is good
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 28 Answers
Hello dear
My name is joy(single). I was impressed when i saw your profile today at and i will like to establish a long lasting relationship with you. In addition,i will like you to reply me through this my private e-mail box(joykind88@gmail.com )
Thanks
waiting to hear from you soon.
joy
I will send to you my pictures
in my next mail through this my mail box
joykind88@gmail.com
Posted on Dec 23, 2015
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 141 Answers
I know this is an old question, but I have just fixed one of these. The problem was C104 inside the metal shielded section of the PSU. It's a 2.2uF 50V capacitor. Sony used an 85?C version rather than a 105?C (which I've used). Fortunately, no other components were damaged.
Posted on Jul 01, 2015
    Champion:
  • 221 Answers
Most likely problem is deteriorated electrolytic capacitors. It's been a while since I saw the inside of a DHR-1000, but I do remember replacing several bad caps to bring it back to life.
Posted on Dec 15, 2009
I mistakenly gave 220volts to my DENON 2808CI. There was a burning smell and denon is no powering up. What must have burned? i opend th etop lid and checked eveyrthing is fine except th epower transformer...
fuses only fail from excessive current and not wrong voltage
take it in for a proper diagnosis but with twice the required voltage , the results will be --junk it and next time used the correct adaptor for the voltage
May 25, 2017 | Denon AVR 2808Ci Receiver
Laptop when using the power off automatic
check bios and make sure you haven't set up an automatic shut down time. if it's just shutting off and not powering down properly it may be overheating. check your temperatures. download hwmonitor (use google) and run it. post your results or take a screenshot and upload it to photobucket or image shack or some other free image host.
Jan 31, 2012 | Computers & Internet
My HTD HD7 has suddenly decided to not respond to any touch functions whats so ever. The screen nore the three function buttons at the bottom register any touch. The remaining buttons, power, volume and...
I'm having the exact same problem.
An hour ago I was using my phone fine, and then it randomly shut off and turning it on again I have no touch function, while the volume and power are fine.
I've done everything recommended, much like you and having no luck :/
Oct 10, 2011 | HTC HD7 Cell Phone
My Acer laptop model number 533Z battery will not charge. I called tech support and they said leave it plugged in, in the shut down mode, for six hours and this would charge it. I have had it plugged into...
Here's one last thing that you can try. Try to remove the reinsert the battery then try to charge it (if you haven't tried it yet). If it will work then it is just a connection problem. Best way to isolate issue is to use a new battery. If not, then return it to WAL-MART. Either the battery pin or the battery contacts (which is connected to the motherboard) is defective.
Hope this helps.
Jul 07, 2011 | Acer Computers & Internet
No Display
Display set to too dark? Tried another monitor, safe mode or another graphic card? If safe mode works, then you might need to update the driver of your graphic card. What setting do you use for the remote connection?
Jul 08, 2010 | E-Machines T6216 (827103077834) PC Desktop
Pioneer hd1bt not powering up all cables are connected and power is running to the unit but still no luck, tried general stuff fuse changes different wires, but still nothing :/ and help ...please?
not enough info you must also give the model and year of the car and if it has an amplified system.
The reason why its not powering up is because the your power source is wrong. You must have a verified excellent ground connected to the black. A constant 12 volts connected to the yellow wire. After you have those two wires connected. Touch the red wire coming from the radio and touch it to the constant yellow just too see if your radio comes on.
If it comes on then your ignition source was wrong.
If it doesnt come on then the back of the radio fuse is blown. Then replace it and try the test again.
If still dont work then your radio is BAD
Apr 09, 2010 | Car Audio & Video
Wont turn on
hello is sound like 1 of the capacitor or transistor have blown. the fuse is located in the power supply glass type if you have to replace the fuse make sure you use the same rated value. the value will be on the end of the fuse or on the fuse holder on the circuit board good luck
regards
shaun
Apr 07, 2010 | Televison & Video
My nokiA3110C NOT STARTED AND WHEN STARTED ONLY SEE LOGO BLINCK 3 TIMES AND THEN SWITCHED OFF BUT NOT CONNECTED PC WITH USB
my 3110c is not powering on, when i press the power button, power supply machine shows some ampere load but phone is not powering on. please give me solution.
Dec 11, 2009 | Nokia 3110 Cellular Phone
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Powering on
Please check if the power adapter is giving voltage output. You can try using a different power adapter.
Oct 08, 2008 | Pioneer AVIC-F900BT Car GPS Receiver
Sony DHR-1000 DVHS VCR Logo
522 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
