Question about Kitchen Ranges
Stove top burnners
Top burners were on and made a popping noise then went out they heat up a little bit when you turn them on but they dont light up like there supposed to and the oven still works
  • 999 Answers
Check your 240vac line. One leg of the circuit is out at the wall or in the stove. Most likely the other leg is backfeeding and they are operating on 120vac now.
Eric
Posted on Dec 11, 2009
I have kenmore stove, one of the burnner is not lighting up auto. how to light with pilot light?
No pilot light, uses piezoelectric to light gas, so you could use a match to light the burner...Proceed at your own risk, DO NOT DO THIS IF YOU DON'T KNOW WHAT YOU ARE DOING
Check next to the burner that is not working for any buildup
The part that produces the spark is white with a short piece of metal sticking out the top,,,the spark arcs over to the burning igniting the gas
Sep 10, 2017 | Kenmore Kitchen Ranges
Hotpoint electric stove burners wont heat up
Water ingress has taken the trip out i expect. If only clean water, it may dry out and then you can replace the fuse/breaker. If in doubt, employ a service engineer.
Dec 21, 2017 | Kitchen Ranges
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
L60AT wont relight
EE2 means no ignition. It could be No fuel or low fuel, dirty filter. You need to look at the flame when you try to start the stove. If you have flame then the igniter is good. If there is no flame and a bumping noise you have a fuel problem. No flame and no bumping you may have an igniter problem. Feel around the burner pot to see if it gets hot. A bad igniter will lead to a flooded stove if you continue.
Tom Hawkins
Bethel, Alaska
Dec 23, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ceramic/glass top stove
Lift the ceramic top and look at the burnner to see if it is bad or not.
You only have to take 2 screws in the front of the ceramic top at the bottom, just open the oven door and look at the corners.
Don't forget to unplug the stove first
May 09, 2008 | Kitchen Ranges
On Light Won't go off on cooktop
I am asuming you mean a standard cook top stove.
you should probebly unplug the range because it looks like a short circuit.
!) a shorted or failing burner/control will light to ground
2) every burrner has a fuse, unscreww each burnner fuse till light goes out. that is the problem piece.
3) change heating elements with the element of the same size on the other side of the stove.
4)put fuse back in. if light off - bad elemet - if light on - bad control
bad control - I'm not sure you want to tackle that. but call me back :)
Jan 29, 2008 | Cooktops
Kitchen Ranges Logo
171 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
