Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Ld code on my whirlpool cabrio, won't drain water, what do you do?
  • 230 Answers
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
tzweeb
  • 318 Answers
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Posted on Jan 30, 2009
SOURCE: Cabrio Washer LD error code
same problem here
Posted on Oct 17, 2008
  • 3 Answers
SOURCE: keep getting LD error code on whirlpool cabrio washer
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Posted on Apr 05, 2009
quatlew
  • 141 Answers
SOURCE: whirlpool cabrio giving error message LD-what is wrong
Long drain error can be caused by something plugging the drain hose or a kink. Tale it off th drain while it is pumping out and check for a good flow. If the hose is ok the pump may have an obstruction causing low flow and it will have to be cleaned out.
Posted on Mar 18, 2010
rickead1
  • 1998 Answers
SOURCE: My whirlpool cabrio he 4.5
Error Code - Ld Problem - Long Drain Solution - When the machine consumes 5 minutes or more to drain out water to where the operating pressure switch resets
Posted on Sep 02, 2010
6200 whirlpool cabrio, Ld error code. Usually, cancel, start corrects problems. Now seems like it won't spin. Tried unplugging and restarting, that also didn't work.
most likely a clogged pump drain find it below the drum usually under a plastic lid bottom left if not under the lower panel below the door
find the 3 screws and remove the cover panel and clean the pump by twisting the pump valve cover counter clockwise
WHIRLPOOL CABRIO WASHER ERROR LD The Cabrio Washer LD error code stands for Long Drain which means the control has recognized the water in the tub is not draining fast enough during the cycle.
  1. Make sure the pump and drain hose are clear of debris that would cause a blockage.
  2. Check the impeller on the drain pump and make sure its not wobbly or busted.
  3. Remove the tub hose from the pump to the tub and check it for blockage.
  4. Make sure the pump is running when and getting the proper voltage when it should be.
  5. If all the above checks out then replace the drain pump motor.
Feb 14, 2018 | Whirlpool Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Flashing Ld on display
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Cabrio Manual
More topslosher failure codes and explanations are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does ld stand for
LD = Long Drain
ld flashes when the water level does not change after the drain pump is on.
Is the drain hose or the drain pump clogged?
Is the drain hose height greater than 96? ?
Is the pump running?
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio he 4.5 cu ft washer keeps throwing the LD code what do I do?
Sep 02, 2010 | Washing Machines
Washer will not spin after draining.
the long drain code means that either the pump is bad or there is an obstruction to the water flow.  check the hose going to the washtub and also check for obstructions in the hoses at the pump itself.  if clear the pump is probably bad.
Aug 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code
taking too long to drain,there is somthing in the drain pump intake or the drain hose is kinked. there could be somthing in the pressure switch hose makeing it think it still has water in it
Dec 08, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool cabrio washer has ld code. have checked pump as well as inside the washer by taking basket out & nothing is plugged up. there was a small amount of water in drum when we removed basket....
Please see the following Whirlpool service manual for the Cabrio washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96˝ ?
• Is the pump running? If not, see TEST #7.
Oct 20, 2009 | Whirlpool Washing Machines
My Whirlpool Cabrio (WTW6600SW1) drains completely then Ld error!
I have a call with the same problem. Pumps all the water out but still flashes LD. Should be the board, The electronic pressure switch is built in to the board. Make sure the pressure chamber on the back right side is not cloged
Aug 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jan 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,100 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
