Question about Whirlpool AWM8143 Front Load Washer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
1st problem indicated a draining fault cleared all filters pipes pump etc.. drained the machine set it to a wash and it washed away for 1/12 on a 35 min cycle. never switching to a rinse or spin, could this be a programe fault? as now i cannot get any programe to work, on a drain it just pumps away until it then dsplays a draining fault "P F" but the machine has drained please help!
  • 1 more comment
  • ark01 Feb 08, 2008
    Yes, I have exactly the same problem. It took 3 hours the other nigth to do a cycle, after I've drained, spun, spun again etc...
    Help please.....
    The code P and F appears but seems to be an intermitant fault?
  • Anonymous Mar 05, 2008
    I have whirlpool AWM8121.
    Set to a wash and it washed away on 35min cycle, after rinsed - the appliance will not start and lamp is flashing never switching to Spin/Drain
    please help!
  • Anonymous Mar 23, 2014
    Stops and won't drain or spin.
    Not on rinse hold.Filter and drain pipe all clear
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Posted on May 07, 2008
I have fp light up on my system and it wont finish its cycle also wont drain
Posted on Dec 03, 2008
i have a whirlpool 6th sense washing machine, it has come up with a red light saying clean pump, does anyone know where the pump is please, ive lost my handbook!!
regards
jackie
Posted on Mar 14, 2008
All you can do is see if there is a reset method for your machie.ie by pressing a combination of buttons supplier gives or if not, the board will have to be replaced.
Posted on Jul 15, 2008
6ya staff
SOURCE:
Whirlpool 6th sense chrome ac is showing the clean filter indication is showing after cleaning the filter what shall we do now? how could we clear the indication
Hi i had the same problem and did exactly as u instructed but its not working. I checked the filters hundred times but there s not a speck of dirt visible. What can it be?
Jun 23, 2014 | Whirlpool Heating & Cooling
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Whirlpool 6th sense fridge freezer instructions
unplugging the unit for 10 minutes is the reset feature. other wise I refer you to the owners manual
Dec 22, 2017 | Whirlpool Refrigerators
Whirlpool 6th Sense AWOE8759B Wont drain or spin
look for the filter under the machine or sometimes on the front behind a flap and clean it out along with the pipes and hoses all leading from the pump to the drum some times you may find the waste pipe is blocked
Jan 19, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Clean pump light keeps coming on
That is the way to fix the issue. remove the debris and hope nothing else gets caught in the trap
Jan 19, 2009 | Whirlpool AWM8163 Front Load Washer
Fp fault
i have the same fault on the whirlpool AWM8163/3 it indicates a drainage problem so check the filter and pump housing and all the pipes for blockage, even the drain pipe, i have done all that but the problem still exists, I'm gunna have another crack at it now and i'll let you know how i get on
Jul 29, 2008 | Whirlpool AWM8103/1 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
2,291 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
