Question about Regal Ware K813BK La Machine Food Processor
Manual for Regal La Machine Food Processor
Manual for regal food processor
  • 1170 Answers
SOURCE: Need Manual for Moulinex La Machine Food Processor
You can download the manual fro the following link.
http://www.moulinex.com/services/product-manuals/download-manuals.htm.
Please rate me if my solution proves useful.
Regards
arjun
Posted on May 02, 2009
SOURCE: I need a detachable stem
Hi... if you have a La Machine I, the item you want is available on nelsonappliance.com for $6.99 + s&h. Search for "disk adapter". I'm not sure about the La Machine II, but the phrase "disk adapter" will probably help you search. Good luck!
Posted on Nov 08, 2008
  • 58 Answers
SOURCE: I need a replacement part for a Regal La Machine Food Processor
the disc adapter part number m52ep003 has been discontinued from production, and no substitute part has been made. Replace unit due age and parts availability.
Posted on Jul 02, 2009
SOURCE: I need a blade holder disc no. m52ep006wht for a
I have a La Machine that I just broke the Disc Adapter on and found out it is now discontinued, so I can't get a replacement part on. So I will sell you the blade holder if you want.
Posted on Sep 24, 2009
dcramer531
  • 1654 Answers
SOURCE: regal food processor/ lamachine1 model
The motor has a plastic gear that breaks easy. It is hard to find, but the solution is to replace the plastic gear. you can find most of the parts for this machine at http://abtecparts.com/Moulinex_Regalware_La_Machine_I.htm
    Dealing with a worn or broken belt
  1. 1
    Unscrew the machine's base, using a screwdriver. You may need to pry off the rubber feet to access some of the screws.
  2. 2repair-food-processor-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a00/3d/qh/repair-food-processor-1.2-800X800.jpg'); });
    Inspect the drive belt (see A). If it is slack, loosen the screws holding the motor assembly (see B), and follow step 4 to increase the belt's tension. If the belt is broken, get a replacement from an appliance store or the manufacturer.
  3. 3
    Install the new belt. Loosen the screws holding the motor assembly, and shift the drive gear toward the reduction gear so you can slip the belt over each gear.
  4. 4
    Shift the drive gear away from the reduction gear to increase the belt's tension, then tighten the motor-assembly screws.
  5. Dealing with a worn drive gear
  6. 1
    Inspect the drive gear. If the teeth are worn, you need to replace it. Remove the drive belt as described above to access the gear.
  7. 2
    Remove the gear, using an Allen (hex) wrench to loosen the setscrew in the side. Then buy a replacement from an appliance store or the manufacturer.
  8. 3
    Slide the new gear onto the drive shaft, and align it so the center is parallel to the center of the reduction gear. Tighten the setscrew with the Allen (hex) wrench.
  9. 4
    Replace the belt, and increase the tension as directed in step 4, above.
  10. 5
    Reinstall the base and any rubber feet you removed.
Posted on Dec 26, 2010
I need a disc adapter for model V663-1-9
I am sorry we have no parts, just advice on repair related topics.
Oct 02, 2012 | Regal Ware K813BK La Machine Food...
Need replacement food pusher for Moulinex regal ware La Machine II, model LM2
This is For Your Information. The covers for that food processor have been recalled. Click on this link for more info:
http://www.cpsc.gov/CPSCPUB/PREREL/PRHTML89/89069.html
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Regal Ware K813BK La Machine Food...
Aug 05, 2009 | Regal Ware K813BK La Machine Food...
Jul 02, 2009 | Regal Ware K813BK La Machine Food...
I need a detachable stem for the slicer,grater discs on the Regal La Machine electronic food processor, Model LM6 375W. TIA, Jo Ann Alexander
Jul 05, 2008 | Regal Ware K813BK La Machine Food...
Food Processors Logo
2,359 people viewed this question
Top Regal Ware Food Processors Experts
Marvin
Marvin
Ross Keen
Lawrence Oravetz
Are you a Regal Ware Food Processor Expert? Answer questions, earn points and help others
