Question about Brother HL-2030 Laser Printer
My Brother HL-2030 won't work; All LED lights are flashing
My Brother HL-2030 won't work. All the 4 LED light are flashing. What to do?
    Top Expert:
  • Brother Master
  • 28,685 Answers
Use the software to diagnose the problem or check for a paper jam and ensure the drum and toner is OK.
Posted on Jun 05, 2017
jwildish
  • 22 Answers
SOURCE: paper light flashes red...
I found just doing this one simple thing sorted the problem.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab on the top shaped like an arrow/triangle? Slide the tab from right to left - reinsert toner close door.
Hope it works for you
JPW
Posted on Oct 30, 2008
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
  • 35 Answers
SOURCE: brother hl-2030
Hi from what i have read on the internet and past experience with these printers (our company has 20 -30 of them) the fault is within the printer and requires a service call from brother.
if its still under warrenty i would suggest taking it back for a replacement if that is not possible but its still under warranty ring up brother in your country and get them to send out an engineer. we have just had another one of our printers start doing this after some routine maintance (we simply used compressed air cans to clean out any "rubbish where the toner / drum assembly goes) after that the printer is now flashing all 4 lights.
sorry i cannot be more positive about the problem but as mentioned its a fault within the printer that requires an engineer.
Posted on Dec 04, 2008
  • 13433 Answers
SOURCE: where can I get brother hl-2030 LASER PRINTER DRIVER
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 05, 2009
komguy
  • 2306 Answers
SOURCE: Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Posted on Jul 30, 2009
Paper light flashing when paper tray is full
Paper got stuck in my HL2030 printer I cleared it but red light keeps flashing and won t let me print.
Feb 17, 2011 | Brother HL-2030 Laser Printer
My Brother hl 2030 has a permanent paper led light flashing altho there is no paper jam and all covers are secure
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 09, 2010 | Brother HL-2030 Laser Printer
Jul 30, 2009 | Brother HL-2030 Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
HL-2030 Continuous Paper Light Flashing.
i looked at the service manuals, there is not one for the hl-2030, however for the hl-2040 is indicates that the front cover or back cover door is open, check the back door and see if the sensor is moving freely.
May 25, 2009 | Brother HL-2030 Laser Printer
Paper light flashes red...
JPW
Aug 30, 2008 | Brother HL-2030 Laser Printer
Brother hl-2030
Aug 13, 2008 | Brother HL-2030 Laser Printer
Brother hl 2030
Hi here is a link to the brother site with a breakdown of the led status lights.
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=eu&c=gb&lang=en&prod=hl2030_all&Cat=6
There are quite a few reasons as to why the paper light is coming on.
the obvious ones are a paper jam, low paper or no paper or its expecting paper to be put into the manual feed on the front of the printer.
but there are a few less than obvious reasons as well according to brothers site.
hope this helps.
Jul 03, 2008 | Brother HL-2030 Laser Printer
Drum problem
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/monolaserpri/hl2030_all.html?reg=us&c=ca&lang=en&prod=hl2030_all
Make sure the printer is "ON" and the drum led to...
Open the front door, Push and hold the "GO" key for about 4 second, all leds are suppose to light...When alls leds light release "GO" key....
Now take the unit out of the printer ...
By pulling down the blue lever take the toner unit out of the drum unit...
And put it in the new drum unit...
reinstall the unit in the printer close front door and check that the drum led is "OFF "
Mar 26, 2008 | Brother HL-2030 Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL-2030 Laser Printer Logo
1,082 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
