Question about HTC P3300 Smartphone
I've P3300. How so ever I charge the phone, its not standing for even 1 or 2 calls. The battery is draining very quickly. How can I fix it ? I gave it to some local Mobile servicing guys, who gave no hope to fix it. I didn't try with Customer care yet.
  • 813 Answers
Have you tried changing the battery? might be the battery is dead and need to be replaced.
Posted on Dec 11, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 67 Answers
The problem is with the phone internals. I too have a similar problem, a new battery from HTC customer care centre also behaves the same. While if no calls are received or GPRS, WiFi & bluetooth are off, the 'battery power remaining' indicator shows hardly any drain.
Suggest use a emergency charger when talking or a USD charger and charge phone right after talk.
Posted on Dec 18, 2009
My 1999 ford expeditin wont hold a charge i ve replaced battery and alternator and voltage regulator
hold a charge when, and stop guessing, please !
state when
and under what conditions.
here, are some simple examples.
car battery drains as i sleep (phantom drain, dark current)
car battery drains, as I drive.
battery will not hold a charge battery sitting on my work bench.
just 1 clue?
this is all easy, to fix. and find. post the full symptoms.
Oct 26, 2013 | Easy Quick Auto Jumper Recharges Vehicle...
Nokia n96 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 17, 2012 | Nokia N96 Smartphone
Xperia Play Battery Drain and screen malfunction during charge.
Apps and services in the background drain your phone even while in standby mode. Turning off your 3G or 4G connection will deprive you of the internet but it will still permit you to get phone calls. Meanwhile, you are not having apps such as Google constantly draining your power in the background. And they are, even in standby mode. Charge your phone frequently to help preserve battery life.
Sep 17, 2017 | Sony Ericsson - Xperia PLAY Mobile Phone -...
My phone is not getting switch on
Maybe you need to charge your phone's battery is drain already. Try charging it, so it will open.
Thanks.
Aug 20, 2010 | HTC P3300 Smartphone
Quick discharge within 1day even when switch off
hm ur battery life s gone....replace it.... hope ur following the safe way to use a battery....... always charge the battery only after the battery gets fully drained!!!!! thanks for using fixya!!!!!!!1
Nov 01, 2009 | Nokia N72 Cellular Phone
I have htc p3300. once started charging its get switched off automaticaly
does the charge light stay on (orange led) on or does it go green or flash on-off orange?
could be battery issue..
on the charge slot on the bottom of p3300 there will be 2 bins left and right inside. try bending them slightly - ONLY slightly tho incase it snaps.
use a needle.
its wat im doing at the moment, im currenlty trying to figure this out so ill keep you informed if i find the soloution.
atm i have to have my phone on charge to use it, otherwise it just goes off but thats how im getting it to charge atm.
if im not in touch..
raving_nanza@hotmail.com
Oct 28, 2009 | HTC P3300 Smartphone
Htc p 3300
dismiss all messages/notifications (for NO Blinking amber light), disable vibrate
attach the original charger, keep phone on a flat surface, find optimum position where the amber light is continuous.
repeat same if you answer any calls or move the phone
May 14, 2009 | HTC P3300 Smartphone
When put phone for charging red light indicate for micro second .phone complet dead again after 3-4 attempts same hppen phone is dead.HTC P3300
where you plug your charger in..
youl be able to see the connections. well there is 2 more on the outer side. just sprise them a little bit with a pin or needle.
dont do it too much as you might snap the connection.
this should work coz im doing it atm.lol
this is only a quick fix.. but you will be able to charge your phone.
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
Battery drains with in 4 hours, cell gets heated during call
Next time you call motorola, ask them to change your phone and not the battery. Your phone has the issue. The battery is being used up due to some error on the phone itself.
Sep 16, 2007 | Motorola Mobility L6 Cellular Phone
HTC P3300 Smartphone Logo
91 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
