Question about Samsung CLP 300 Laser Printer
Printer has red light.wont print - Samsung CLP 300 Laser Printer
  • 1 more comment
  • wiffle11 Dec 11, 2009
    tried opening up back door. doesnt work. checked paper and its snug and it still doesnt work. red light is still on and wont print. any recommemdations?
    thanks
    ken
  • wiffle11 Dec 12, 2009
    tried everything listed.
    solid red light.
    my blue and red toners are lit red as well.
    please help
    thanks
    ken
    tried all .red light still on.
    my blue and red toner lites are on as well (red lit) . can this b the problem? i need new color toners? why wouldnt it print just black if so?
    please help.
    thanks
    ken
  • 10,515 Answers
Wow!!
One more Customer falls with this Problem.Mr Wiffle, this is a Common problem with This Model.Usually these symptoms are there just after paper Jam.Most of the Times, if you call Samsung, they would tell you to clean off the Rubber Piece with alcohol, and also take a knife to the rubber piece to rough it up to create more traction.If the Problem Persists, they would tell you to Replace the Parts.
You need to think before you get this Unit Repaired/Cleaned by a Tech :-
1. Cost Quote
2. How Old the Unit is?
3. Life Expectancy of these Printers
4. Investing in New Printer
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
  • 2,567 Answers
If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced.
If your printer's On Line LED is glowing solid red, then the cause might be one of the following:
  • Printer paper is jammed inside your printer.
  • A cover is not being closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Important: Before you perform any type of service on your printer that requires you to open the printer, turn the printer off, and then unplug it from the wall outlet.
Posted on Dec 11, 2009
  • Mohamed Omran Dec 11, 2009
    Fixing Paper Jams
    Paper jams usually occur
    in three areas of a printer. The following error messages indicate the area
    in which the jam has occurred:
    • Jam 0 indicates the
      paper failed to pass through the first sensor.
    • Jam 1 indicates the
      paper failed to pass through the second sensor and has jammed around the
      toner cartridge.
    • Jam 2 indicates the
      paper failed to pass through the second sensor and has jammed near the fuser.
    Directions to fix the paper
    jams indicated by each error message are below.
    Paper
    Jam 0
    When your printer displays Jam 0, paper has failed to pass through the first
    sensor.
    To remove the jammed paper, follow these steps:
    1. Power your printer off.
    2. Open the cover of your printer.
    3. Gently pull the paper toward you to remove it from the printer.
      Note:
      If you do not remove the paper slowly, you can damage the printer and the
      printer will require service.
    4. After removing the paper, make sure there is no additional paper in
      the paper path.
    5. Close the printer cover, and then power on your printer.
    If your printer still displays Jam 0 after you turn on the printer, unplug
    the printer, and then repeat the steps above. Make sure all paper has been removed
    and the printer's rollers are in their correct positions. Before turning your
    printer back on, make sure all the cover doors are fully closed.
    Paper
    Jam 1
    When your printer displays Jam 1, the paper has failed to pass through the
    second sensor and has jammed around the toner cartridge.
      Note:
      the printer will require service.
      paper in the paper path.
    If your printer still displays Jam 1 after you turn on the printer, unplug
    been removed and the printer's rollers are in their correct positions.
    Before turning your printer back on, make sure all the cover doors are fully
    closed
    Paper
    Jam 2
    When your printer displays Jam 2, the paper has failed to pass through the
    second sensor and has jammed at the fuser.
      Note:
      the paper path.
    If your printer still displays Jam 2 after you turn on the printer, unplug
    closed.
  • 3,230 Answers
First of all try the following -
To fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
post further comments if you have same problem again.
Good Luck!!
Thanks
My Lexmark x2670 wont print colour red
Make sure the magenta cartridge is not empty.
If it's not, then try the print head cleaning function in the printer utility window. In "Devices and Printers" select the printer in question to get the window
Feb 02, 2015 | Lexmark X2670 All-In-One Printer
Wont print. solid red ink light. wont display ink levels
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Nov 18, 2011 | Office Equipment & Supplies
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
May 15, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Maintenance warning/technical issue message stops printing
You just need to reset your printer. Google search a resetter program for your printer model.
Jan 10, 2010 | Epson Office Equipment & Supplies
Red light on wont print
YOur printer need to be resetted, which is possible through a reset software or hardware module.
www.nakshatraworld.com
Dec 11, 2009 | Samsung CLP 300 Laser Printer
Red alarm wont go off and printer wont print
Damaged Hardware or firmware. Chances are the printer wont tell you which part.
Sorry. IF you can find a schematic to locate the broken part and replace it yourself, that may be of use to you.
Nick
Sep 03, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Samsung CLP 300 Laser Printer Logo
48 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
