Washing machine programme says f11 so wont do a wash cycle cant find manual
  • 3 more comments
  • Decs Apr 24, 2008
    F11 appeared after 11 minutes of wash cycle.
    1)Cleared screen by pushing cancel twice.
    2)Unplugged washer for 10 min. plugged back in and pushed "drain and spin". F11 code reappeared.
    3)Removed all hoses to water pump and removed light debris from water pump.(childs toy)
    4)Re-attached hoses and pressed "rinse and spin". F11 reappeared.
    Machine will not spin or pump water out at all.
    Is it just the water pump or should the drum spin, rotate or move at all in any of the cycles? I have tried all cycles and drum will not move at all.
    Belt is intact and in good shape.
    Drum can spin freely by hand.
    I would appreciate any help!
  • claudius57 Sep 16, 2008
    I, have the same problem. The washer will not work. It starts and jumps on F-11. What can I do to fix the problem. Or must I call a rapaire man.
  • strelley Oct 31, 2008
    the machine will fill then start then after a minute f11 appears ,no matter what you do it doesn't go away, it will not drain or spin or wash.
  • Rick Holcomb Apr 05, 2009
    We have the same problem with the F11 error code. Our washer seems to work until it gets to the rinse and or the drain and spin cycle.
    If anyone has a suggestion, we have looked in the manual and can't seem to find anything.
  • Jennifer9073 Apr 19, 2009
    I have the same problem: the washer begins the cycle for about 10 seconds and then stops, beeps, and displays F11. The manual just says "electrical problem" and to call for service. Does anyone know something I can try before doing that?
Stops in the middle of a cycle and display reads f1
Posted on Apr 03, 2008
How to use the shoe rack in a front open whirlpool duet ht dryer?
Posted on Mar 29, 2008
    President:
  • 1,294 Answers
Click on washing machines (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 20, 2008
Washing machines problems
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
Dec 09, 2017 | Washing Machines
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Aug 26, 2012 | Bosch Logixx WFT 2806 Front Load...
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
A 40 degree cotton wash takes around 3 hours to complete cycle, manual states 90 minutes, any ideas ?
It is possible the heater element is not working, you need a meter to test it with, and make sure you have selected the correct programm for what you are washing as some programmes can take up to 3 hours to complete.
Hope this helps.
Jan 11, 2010 | Washing Machines
Washing machine is stuck on the washing cycle and wont switch on to the rinse cycle
Does the machine drain out and do a spin cycle?
If it does then the Programmer is shot, it should impulse on by itself at that point but if the pump is not running it will sit there waiting to fill with clean water
Jan 02, 2010 | Washing Machines
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
421 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
