Question about Cell Phones
I have a HTC Touch Dual 850 and have problems
I have a HTC Touch Dual 850 and have problems answering calls when a reminder message is active
My htc touch reminders won't sound. The general alarm works but not the reminder alarms in the calendar, texts, e-mail, missed calls etc all sound, just not the calendar reminders
From what I have already experienced so far, some WM6 builds seem to be prone to have their notifications queue messed up.
Google for 'checknotifications_arm.cab', intall it on your device, and tap on 'Options > Settings...', tick both checkboxes there. Tap ok,' and 'Clear', at the top of the application's screen. Your notifications queue will be free of garbage, now.
Then, go to your Calendar application, choose a day which has the next events with notifications (reminders), Edit each one of them twice: one to delete the Reminder settings, and another one to reset them (you'll notice that at the 2nd edititing action for each event, the Reminder settings will be shown as they were, prior to their deletion - less work to be done!). This will set Calendar entries in the notifications queue.
Your reminders should work from now on.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 12, 2010 | HTC Touch P3450 Smartphone
Trying to connect to internet on a htc p5500
Call your provider. They will give you the settings.
Jan 07, 2010 | HTC Touch Dual Slider Smartphone
How do i set up call diver if unanswered on htc
start>setting>personal>phone>services>select call forwarding(click get settings)>select(under forward phone calls only if) no answer (number)
Nov 06, 2009 | HTC Touch Dual Slider Smartphone
My son's HTC Magic has the same problem!
Try Start-Settings-Connection-Calls.
Sep 20, 2009 | HTC Touch Pro Smartphone
HTC Touch Dual not recognized by PC
if you run vista it will not recognise the drivers, you will need to download an update from HTC or from your mobile operator.
faling that check microsoft vista website for mobile device software- vista does not use active sync
Aug 13, 2009 | HTC Touch Dual Slider Smartphone
With call waiting when you are on a call and another call comes through it disconnects you from the call you are on how do you stop this from happening?
1) Check if you have enabled auto answer facility in your phone.
2) Cancel all Call Divert options.
3) Cancel Call Waiting
4) reactivate call divert if already have.
5) Activate call waiting.
Now try, as I have the same problem with HTC TyTN II, I got solved this way.
Jul 22, 2009 | HTC Touch HD Smartphone
HTC Touch Diamond problems with Manila.exe, Shell32.exe, reboot
May be this is because of using older ROM's i.e firmware..
Goto HTC site and find the updated ROM for ur device..
Current version of ROM's may have fix for ur problems...
Take backup of ur data before updating the firmware....
Thanks,
Jegan..
Dec 11, 2008 | HTC Touch Diamond Smartphone
Verizon?
The carriers who use non sim phones for their network are most likely to use a CDMA 450Mhz Network. Most phones with a sim slot will work on GSM 900-1800-1900 Mhz bands, with their subdivisions (like 850-950 domain, 1800-1850). A phone with a sim card uses a RF module tuned on a specific range of frequencies. The major ones are GSM, CDMA and UMTS (HSDPA included). There are phones with support for GSM + UMTS - most 3g phones available on marked. In your case, a GSM HTC touch Dual will work on gsm networks. For verizon or other cdma networks, HTC produces a CDMA version of the Touch Dual. If you have the gsm version (the one that needs a sim) you should use it on gsm carriers.
Hope this helps.
Jun 19, 2008 | HTC Touch Dual Slider Smartphone
HTC Touch Screen has many unresolved/unexplained poblems
I had the same problem and by mistiriously way, when connected to PC wiht the USB cable, it became alive!!!!
Mar 03, 2008 | HTC Touch P3450 Smartphone
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
