PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Laptop is Possessed
By heatmeiser on Jan 20, 2008
I've had my Toshiba M45-S359 laptop now for two years, and it had been running beautifully. However, it suddenly started to act up. Here's a basic rundown of what it's doing:
1. The touchpad mouse has stopped functioning. Windows recognizes it, and I've tried updated drives and such. But it has just stopped working.
2. The video (from Post to Bootup, and sometimes even after Rebooting) will sometimes automatically lower the resolution to basically 1024 x 768, so the LCD will physically only display within that region, leaving a solid black bar to the right and at the bottom of unused space.
3. Sometimes when the video acts up, the laptop will hang up at it's post.
4. Once it does boot, it will automatically reboot after anywhere from 2 to 20 minutes.
When this first started to occur, the wireless NIC, SD Card slot, and touchpad all failed. I assumed maybe a single board in the front had been the culprit. Then eventually both the SD Card and wirelss NIC came back online, but then the Modem/Wired NIC failed, as well as the touchpad. As it stands now, only the touchpad is still without function (I haven't had a chance to retry the SD slot).
This is something that is occuring with both the Windows XP Home edition that I reinstalled from the Restore CD, and a copy of Windows XP Pro that I installed "clean" with only most-recent device drivers.
I'm assuming that a heat issue is the cause of the rebooting. But would this also affect the other issues?
I've also noticed that the power plug is loose, and sometimes if i simply unplug the power cord, the laptop will get past its post hang-up. But the video will remain reduced thruout my session, and sometimes even after a few reboots.
If anyone could shed some light on to what could be the cause of the problem, I would appreciate it. I will be getting a can of compressed air in the morning and try to blow out the fan / heatsink to see if maybe that will cure the rebooting issue as well as maybe some of the others.
Solution #1
posted on Jan 21, 2008
Not Helpful)
rawoo
Rank: Master
Rating: 77%, 20 votes
well so mush problem
well it could because of virus so to do a complete back up of ur files.then re install the operating system.dont forget to reply me on rawoo_ravi@hotmail.com
Was this helpful?
Yes
No
Solution #2
Not Rated)
King_P
Rank: Wiz
Rating: 83%, 69 votes
If the power socket or D/C socket is loose or causing any problems then i would strongly suggest getting that sorted out first. It could be power fluctuations causing your problems. also when it is disassembled you should dry run it with the bare minimum to boot it and see if it still overheats. Being only two years old i would say that you would definetly benefit from professional help as the cost is outweighed by the value.
Was this helpful?
Yes
No
Solution #3
Not Rated)
hughv
Rank: Wiz
Rating: 82%, 317 votes
I think you're on the right track with the heat idea
It couldn't hurt to reseat the memory card(s).
Take this thing apart as far as you dare for thorough cleaning.
Look in Event Viewer for System errors and device manager for problem hardware.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
webcam driver open fail. Unistalled and reenstalled but isnt working. What is the next stop
Answer
Push power button nothing happens unless I also push cover limit swithch then start to power up but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , IL
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
