Question about Keurig Coffee Makers & Espresso Machines
After deliming the pot says not ready - Keurig Coffee Makers & Espresso Machines
I bought a new pot
Posted on Dec 12, 2009
What brand of deliming agent should be used when deliming this unit?
The chemicals used for this unit are not brand specific. As long as you are using a commercial-grade delimer, you will be fine. Do not pick up a delimer from your local supermarket. Those are not designed for commercial warewashers and can cause further problems. Ecolab is a common brand used . The have a delimer called Lime Away that is very widely used. Also, please remember to drain the water out of your dishwasher and disable your detergent and rinse aide before filling it back up. Then add your delimer and run the unit in manual mode for as long as necessary. Then, drain the unit again, rinse out the wash tank area, enable your detergent and rinse aide, and fill the unit back up. You should be ready to run now.
Jun 17, 2015 | Meiko K44E Dishwasher
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
I have two and both are having problems! The first one - when I put a whole pot of water in only a half pot comes out. If I put another whole pot of water in on top of that still only a half pot comes...
  • The sprayhead may be clogged. Check the round disk (sprayhead) above the brew funnel. The holes in this part must always remain open. If they are clogged, remove the sprayhead and clear the holes using a toothpick. Always unplug the brewer before deliming or cleaning the sprayhead.
  • The brewer could be clogged with mineral deposits. See the Deliming Instructions in the Manual. NOTE: The frequency of deliming depends on the mineral content of your water.
May 16, 2011 | Bunn VPR Coffee Maker
Cleaned my pot but the water is running very slow. when I emty the pot the water flows very good out of the hole but when I make the coffee is does not flow very well taking about 15 min to make a pot of...
First thing to check is that there is no blockage in the funnel. Next thing is check the spray head and make sure that it is not limed up. After removing the funnel there will be a round silver head that screws in above the funnel, it can be removed by hand but usually you need a pair of channel locks. If so you can clean the spray head with a wire brush. Also if that is not an issue you can purchase a deliming spring from http://www.google.com/imgres?imgurl=http://ecx.images-amazon.com/images/I/21IeXJoqjnL._SL500_AA300_.jpg&imgrefurl=http://www.amazon.com/Bunn-Commercial-Deliming-Spring/dp/B0032QNRH2&usg=__mJkJExy1qExfrZEEbtxW6EAQGSw=&h=300&w=300&sz=5&hl=en&start=4&zoom=1&itbs=1&tbnid=tHf1BPtEJIafsM:&tbnh=116&tbnw=116&prev=/images%3Fq%3Ddeliming%2Bspring%26hl%3Den%26gbv%3D2%26tbs%3Disch:1
WIth the deliming spring you need to remove the spray head and simply run the spring through the hole til you hit the water in the tank and pull it back and forth about 4 or 5 times. Also something siple make sure there is only one coffee filter it is easy to put two in. Hope this helps.
www.midstatebeverage.com
Dec 01, 2010 | Bunn Pour-O-Matic VPR
I have a Fresh Start Oasis model fstb-p60-100 coffee maker at work. Problem is, sometimes it brews only a partial pot of coffee then the next time it will overfill the pot. I am looking for user and repair...
There is probably a scale deposit around the tank outlet that leads to the sprayhead. Unplus the macine from the wall. Remove the top cover. Pull on the black rubber connector that leads to the sprayhead until it comes off. Insert a Bunn Deliming spring into the black rubber connector and feed it into the tank, run it back and forth several times. Remove the deliming spring and reconnect the black rubber connector. make sure it is on all the way around. Replace top cover. Pour in a pot of water. you should get an instantaneous flow of water from the brew basket.
Oct 16, 2010 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Pot only filling half way
If pot used to fill all the way then check the filter if one is installed and the restrictor on the back of the tank, you can also run the deliming spring through the brew tube.
If the pot never filled all the way then remove the front panel and use the instructions to reprogram the brewer.
Sep 24, 2010 | Bunn CWTF15-TC
Lime in coffee pot
We recommend cleaning your machine with white vinegar for 2 hours and then using the metal deliming tool under where the sprayhead is located. IThen flush it out with 8-10 decanters of water. If this doesn't fix your problem, please call customer service at 800-352-2866 with the model and date code.
Jul 20, 2010 | Bunn 10 Cup Home Coffee Brewer
After 2 pots, auto fill makes only half pots?
Descale machine or run deliming spring through the brew tube after removing the sprayhead.
Mar 09, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Coffee Makers & Espresso Machines Logo
150 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
